rear heater
rear heater
help fellow bongo worshippers a week ago i had the heater on in the van and the rear heating was working fine but it suddenly cut out i just put it down to a blow fuse but i have since checked all the fuses and they are fine help !!
1996 2.5 TD white over silver aft bongo
Re: rear heater
Dodgy switch that isolates the rear fan....?? Maybe the contacts need a clean up..?
Re: rear heater
On the lower dash by yer right knee.. Has a fan on it & orange light when on....?
Re: rear heater
ah right the light come on on there but i will clean it tomorow cheers
Re: rear heater
I take it the rear heater matrix is still getting hot...? Just the fan not working..?!!
- Simon Jones
Re: rear heater
If you've got digital heater controls in the front then there will be a button marked Rear which should light up green when pressed.
Re: rear heater
no not digital took the switch out today but no luck no fan at all still broken ?
- helen&tony
Re: rear heater
I'm afraid it's probably a case of take the rear trim out, and check whether you have power at the fan...I replaced my motor. WORD OF WARNING...don't remove the trim 'till summer, as the plastic which holds the trim clips in place is very brittle in winter, and will likely break, leaving you with nowhere to fit the clips back on!
