curtain jammed in sliding door
jamieward
Post by jamieward » Thu Jan 26, 2012 10:51 pm
When we shut the sliding door a corner of curtain got stuck in the mechanism and now the door won't open - either from the inside or the outside.
Any suggestions?
Jamie
Re: curtain jammed in sliding door
Post by Bob » Thu Jan 26, 2012 11:52 pm
Is the it the curtain from the front door stuck in the top of the sliding jobby?
If so I recon it is just muscle, get someone inside and someone outside and give a co-ordinated pull.
If the curtain is stuck in the front of the door, near the handle, a search will reveal the knack of slapping the inside of the door panel to free it.
Edit: And welcome aboard Jamie. :)
jaylee
Post by jaylee » Fri Jan 27, 2012 1:33 am
Has the curtain caught in the vicinity of the sliding door catch....
It may have switched the child lock, but that don't explain why the out side handle don't work..?
Disconnect the battery for a while...? Can't do any harm....
richieb
Post by richieb » Fri Jan 27, 2012 2:44 pm
have you tried dynamite ?
Post by Bob » Fri Jan 27, 2012 3:02 pm
Curtain would just flap about in the blast. :lol:
dandywarhol
Post by dandywarhol » Fri Jan 27, 2012 5:25 pm
richieb wrote:have you tried dynamite ?
I was going to say "Don't do it again" for suggestions but thought it a bit cheeky - you're beats it!
