Bongo has a whizzzzzzz ??? ...Throttle related..??
rhino-wayne
Post by rhino-wayne » Sun Jan 08, 2012 2:50 pm
Hi folks, learner mechanic here again. :mrgreen:
OK, so yesterday my Bongo started making a light whizzing sound when under acceleration :?: :?:
Before I start tinkering about, any ideas :?: folks
Whiz only happens when accelerating with medium-heavy pressure on accelerator pedal....no whiz if being very gentle?? #-o
thanks in advance =D>
Re: Bongo has a whizzzzzzz ??? ...Throttle related..??
Post by Ian » Sun Jan 08, 2012 2:56 pm
Check the number 1 stud on your exhaust manifold gasket, under the passenger seat. Not usually described as a qhiz, more of a squealing pig......
rhino-wayne
Post by rhino-wayne » Sun Jan 08, 2012 3:07 pm
Thx Ian, will check, but more of a large mosquito than a squealing pig :lol:
longhaul8
Post by longhaul8 » Sun Jan 08, 2012 3:10 pm
slipping belt ?
rhino-wayne
Post by rhino-wayne » Sun Feb 12, 2012 9:57 pm
OK, so I discovered & solved the problem... :)
The EGR pipe connection at the front :!: A close inspection revealed that that it was only connected with one bolt #-o and that one and only bolt was loose/threaded and not holding the connection tight :!: :!:
Anyway, fitted a blanking plate (c/o Allans Vehicle Services), A new bolt & all is quiet again :)
Go to find a 2nd bolt or hope the one will hold :?
Post by Northern Bongolow » Sun Feb 12, 2012 10:13 pm
rhino-wayne wrote:Hi folks, learner mechanic here again. :mrgreen:
you can ditch that title now. good info for the next one. =D> =D> =D> =D>
chipvan
Post by chipvan » Tue Feb 14, 2012 1:37 am
