Exhausts
- PisceanJoy
Exhausts
The  back of my exhaust has just fallen off
Haas anyone bought one recently and know how much they are
Have seen how much it is in bongo shop
Re: Exhausts
Fit a straight pipe instead - cheaper, better and fitted by loads of members
- PisceanJoy
Re: Exhausts
without the back bit?
I have a Diesel bongo
Has anyone near me done this?
Re: Exhausts
PisceanJoy wrote:without the back bit?
Hi,I believe that a Ford Connect tailpipe will fit with a bit of fiddling.
Just remember that removing any major part of an exhaust system is a MOT failure,but I think you would need a switched ON Tester to spot it on these vehicles.
Cheers.
Re: Exhausts
Not unless the rules have changed recently. Providing there are no leaks and it isn't too noisy, it will pass an MOT.teenmal wrote:Just remember that removing any major part of an exhaust system is a MOT failure,
- Muzorewa
Re: Exhausts
...and it can't be any noisier than ours from MIJ in Walsall
PS - who I would wholeheartedly recommend
Re: Exhausts
As I've said before the standard "oil drum" is a waste of space and weight.
If you have a decent local garage or exhaust fitter ask them to source and fit a small straight through box - it's all you need.
Re: Exhausts
£47.50 from A TO Z AUTOPARTS (MIDLANDS)LTD.  I just fitted mine today.
						- PisceanJoy
Re: Exhausts
						- PisceanJoy
Re: Exhausts
Have you got a URL / contact no for them google serach doesnt find itAethelric wrote:£47.50 from A TO Z AUTOPARTS (MIDLANDS)LTD. I just fitted mine today.
- Simon Jones
Re: Exhausts
Lots of results on google including this with contact details;
http://www.yell.com/b/A+to+Z+Autoparts- ... index.html
Re: Exhausts
Hi,you could try these people,they have sold quite a lot.
http://www.ebay.co.uk/itm/MAZDA-BONGO-1 ... 1c1a40a62c
- mikeWalsall
Re: Exhausts
						- Simon Jones
Re: Exhausts
Worth noting there are two types of exhaust systems. The most recent link from Mike is the 4 part version for vans with the winter warm up valve fitted, but there are probably more Bongos out there with the 3 part version. While the backboxes will probably be the same in both cases, the front section is not interchangeable. If the front section is in good nick, then I personally would just replace the broken bit.
