I still seem to have a resinating / vibrating noise coming fro the vacinity of the vris solanoid at about 2500/3000 revs
13-140a in the first link
solanoid no2 has been replaced and it appear to be now working well it moves the valve rod when you rev it anyway which it didn't before it didn't work when you gave it 12 volts either so i reckon it was goosed, solanoid no1 appears to work fine works if you give it 12v from the battery, how freely should air flow through the check valve 13-995 obviously it should only flow one direction which is demonstrated on the valve but it is diffacult to get air through it the correct direction, if it is not working correctly could it be possible that this would cause bad vacuum which could lead to my resinating in the surge tank and my lack of go
Or should i be looking elsewhere
I know i should give in and take it to a pro but i'm determined to sort it myself again
What do all you mega techies think help would be apreciated as i want my van back to beasting t4s and vito's and NOT JUST keeping up with nissan micra's
All advice taken on board
DAR
