v6 all noise and no go
cheffy34
Post by cheffy34 » Wed Dec 21, 2011 5:44 pm
Hey Guys here we go again all sorted, cleared the fault codes replaced the vris solanoid and cam sensor no more fault codes, re timed the ignition it is now working and running on idle lovely, but i still have all noise and no go when i give it beans on the gas peddle it all runs tickety boo tho, but just no go just lots of noise as if it is going like the clappers :evil:
I still seem to have a resinating / vibrating noise coming fro the vacinity of the vris solanoid at about 2500/3000 revs
13-140a in the first link
solanoid no2 has been replaced and it appear to be now working well it moves the valve rod when you rev it anyway which it didn't before it didn't work when you gave it 12 volts either so i reckon it was goosed, solanoid no1 appears to work fine works if you give it 12v from the battery, how freely should air flow through the check valve 13-995 obviously it should only flow one direction which is demonstrated on the valve but it is diffacult to get air through it the correct direction, if it is not working correctly could it be possible that this would cause bad vacuum which could lead to my resinating in the surge tank and my lack of go :?:
Or should i be looking elsewhere
I know i should give in and take it to a pro but i'm determined to sort it myself again
What do all you mega techies think help would be apreciated as i want my van back to beasting t4s and vito's and NOT JUST keeping up with nissan micra's :twisted:
All advice taken on board
DAR
Re: v6 all noise and no go
Post by Northern Bongolow » Thu Dec 22, 2011 2:17 am
not sure on the v6 but the one on the diesel i think allows the vac to be dumped under control from the egr solenoids,
if yours is not allowing the vac to be dumped. or fast enough, it could affect what is happening before it.
try removing it and join the pipe together, see what happens, shouldnt hurt for a short test.
the one on the diesel is quite easy to blow through and shuts quickly when sucked.
cheffy34
Post by cheffy34 » Thu Dec 22, 2011 5:48 pm
Thanks NB, i will try that one :wink: I've tried allsorts of things so far changing solanoids, swopping solanoids for solanoids, leaving pipes off that one aswell but to no avail, sometimes i may get a slight feel of power when i boot it but it not right.
Dar
The Great Pretender
Post by The Great Pretender » Fri Dec 23, 2011 1:17 am
DAR
Probably better off taking it to a fuel injection specialist unless you need a little relief :-$ ............... :lol: :lol: :lol:
Is the cam sensor adjustable and if so is it timed in? :wink:
To infinity and beyond
cheffy34
Post by cheffy34 » Fri Dec 23, 2011 1:58 am
The Great Pretender wrote:
DAR
A little light relief would be nice Mr P =P~ but not of the wallet veriety :P
As far as i know (and it aint alot) it isn't adjustable as seperate part [-o< :D i am more than likely to shot down tho :roll: , but i will go thru the manual again and check. It is doin my swede in at mo it is all there :!: just no ooooooomphhhhhhhhh :|
Dar
Post by Northern Bongolow » Fri Dec 23, 2011 4:18 am
you describe it as all noise and no go.
im no expert but does this suggest the engine is fine, does it rev fully when not under load, then fails when the turbo is called into play, if so check this side of things, or the timing of everything again, but sounds like you would spot that, sometimes when your suede is being cooked it can be hard to see the wood #-o #-o .
i find slinging it in the back of the garage for a week works wonders, it usually gets sorted in minuites on return.
Simon Jones
Post by Simon Jones » Fri Dec 23, 2011 9:11 am
Northern Bongolow wrote:...then fails when the turbo is called into play.....
He'd have a long time to wait until the turbo kicks in on a V6 :wink:
cheffy34
Post by cheffy34 » Sat Dec 24, 2011 1:23 am
I can most defo say it not the turbo :D ` trouble is NB the dam thing has been chucked in the back of the garage :roll: but can't live without it
Dar
Post by Northern Bongolow » Sat Dec 24, 2011 1:35 am
oh yeh, i forgot, i fell for that one once before, sorry.
proper cars have em #-o :lol: .
lets have another uneducated guess then---- fuel filter :roll: :wink:
The Great Pretender
Post by The Great Pretender » Sat Dec 24, 2011 1:49 am
Or lambda sensor, could even be what a certain person did when the pr*tt over the road kept revving the dogs do da's off his Fiat at stupid times in the morning. Builders foam up the exhaust.....................Not that I would do it............ :oops: :oops: :wink:
helen&tony
Post by helen&tony » Sat Dec 24, 2011 7:07 am
Ady...
PROPER cars have "Squeezed / injected" V8s with a GM Blower http://www.superchargerusa.com/blowers.htm
Turbochargers are for 'orrible screamy little engines... :lol: :lol: :lol: :lol: :lol: :lol:
Post by Northern Bongolow » Sat Dec 24, 2011 9:27 pm
yes but look at the prices at the bottom of the page for the top ones :shock: :shock: :wink:
dandywarhol
Post by dandywarhol » Sat Dec 24, 2011 9:48 pm
A long shot - make sure the exhaust baffles haven't collapsed and choked the system.................................
cheffy34
Post by cheffy34 » Wed Dec 28, 2011 5:38 pm
Had new lambda so cant see it being that, exhaust appears to be clear.
Would i be right in thinking that all the vris etc is controlled by the TPS dandy :?:
jaylee
Post by jaylee » Wed Dec 28, 2011 6:36 pm
Are all those vacuum hoses connected the right way round Dar?? http://lushprojects.com/bongopartsmk2/c ... o=.html#23
