2 Litre Starting
maxi_77
2 Litre Starting
Post by maxi_77 » Wed Dec 21, 2011 12:11 am
Our 2 litre Bongo is getting more reluctant to start. The present trick is to turn the switch to start and turn the engine over for a bit until it tries to start, then switch off and repeat, normally it then starts. It is then a bit sluggish until it reaches running temeperature when it behaves fine. Any subsequent starts during the day are fine.
Any suggestions other than buy a diesel Bongo
White diesel Bongo
terrybull
Re: 2 Litre Starting
Post by terrybull » Wed Dec 21, 2011 9:04 pm
Sounds to me like the choke not working. My 2L starts on the first turnover every time, the method I use is to press accelerator once to set the choke then keep off the pedal when turning the key. I did have a starting problem when cold (during summer) but that was a battery issue which I'm sure you've checked.
Post by francophile1947 » Wed Dec 21, 2011 10:35 pm
terrybull wrote:Sounds to me like the choke not working.
Do they have a choke :? Thought they disappeared years ago - pre fuel injection :?
mikeWalsall
Post by mikeWalsall » Thu Dec 22, 2011 12:26 am
Usually the ECU tells the injections system that it is cold ... so more fuel gets injected to give a richer mixture until things warm up..
One reason is maybe the temperature sensor is faulty and not sending the right info ..??
Post by teenmal » Thu Dec 22, 2011 1:37 pm
It might be worthwhile checking the operation of the choke, and cleaning the choke sensor plug.
PS What country are you in.
Cheers.
mikeWalsall
Post by mikeWalsall » Thu Dec 22, 2011 1:49 pm
Usually injected engines do not have a choke ..the ECU tells the injections system that it is cold ... so more fuel gets injected to give a richer mixture until things warm up..
Post by teenmal » Thu Dec 22, 2011 1:58 pm
mikeWalsall wrote:Usually injected engines do not have a choke ..the ECU tells the injections system that it is cold ... so more fuel gets injected to give a richer mixture until things warm up..
Hi on these old vehicles it is called the Building Choke.This is the one on a v6.
mikeWalsall
Post by mikeWalsall » Thu Dec 22, 2011 2:21 pm
"The Building Choke" ... on the injection system ..
I must admit it is something I have never heard of.
Post by g8dhe » Thu Dec 22, 2011 3:39 pm
I must admit I am confused between what looks like a Choke and is called a Throttle (with a Throttle Position Sensor - TPS) on modern engines!
Nevets
Post by Nevets » Fri Dec 23, 2011 11:54 am
mikeWalsall wrote:Usually the ECU tells the injections system that it is cold ... so more fuel gets injected to give a richer mixture until things warm up..
correct =D>
I am the only bongo in the village.......(not anymore there's two of us now "Damn it)
maxi_77
Post by maxi_77 » Fri Dec 23, 2011 8:41 pm
correct =D>
Any hints as to where the temperature sensor is?
White diesel Bongo
ginger colin
Post by ginger colin » Thu Jun 05, 2014 12:40 pm
My 2.0 sometimes wanders up from 800rpm to 1200rpm. Then back down. Im looking for the sensor as well.
mikeWalsall
Post by mikeWalsall » Thu Jun 05, 2014 7:11 pm
The sencer numbers are ..18-840c ...... and 18-510 .. dunno where they are situtaed ... I would check around the water pump area ..
http://lushprojects.com/bongopartsmk2/c ... 2of02.html
