hi peeps
well i just took the eldest home from flicks when i noticed i had no speedo and the hold light was flashing ,but when i switched off the engine and back on again all was well ,should i be concerned about this or is it usual bongo jiggery pokery
thanks in advance
hold light flashing
sarahndaz
Re: hold light flashing
If your speedo is chipped to read in MPH,I think its a sign that the chips duff
Brian
Brian
there have been reports of the speedo chip acting up and causing this type of thing, if it persists remove the clocks and check for loose wires where its been wired in, or check the screws on the back of the clocks, make sure they are nipped up, BUT NOT OVERTIGHT.
sarahndaz
thanks guys i will do my checks today and report back to bongo hq
- haydn callow
Hi.
It happens to ours a couple of times a month....switching off and on again sorts it....I had the reason explained once....somthing to do with the pulses getting out of sync....nothing to worry about.
