Changing headlight bulb
Bogmonster40
Post by Bogmonster40 » Wed Dec 14, 2011 10:07 pm
Even this would have been something that I would have popped into a garage to have done in times gone by :oops: :oops
Do I just remove the 8mm bolt to take the headlight out then change the bulb ?
I am very sorry for having to post these inane posts on here, hopefully I will be able to drop my engine and do a full overhaul in the near future - and it will be all thanks to these forums :roll: :roll:
V6 2.5i Tintop Aero Petrol/LPG
Re: Changing headlight bulb
Post by g8dhe » Wed Dec 14, 2011 10:33 pm
Not in vehicles before 1999, just pull the plug off the back of the bulb, and release the spring clip, oh and the rubber gaiter, when releasing the spring watch which way you need to squeeze it to release the clip so you know how it goes back on again. The bulb only fits into position one way, now reverse the process.
Bogmonster40
Post by Bogmonster40 » Wed Dec 14, 2011 11:32 pm
thank you geoff - i will have a look in the mornning......
Post by Northern Bongolow » Thu Dec 15, 2011 5:18 am
dont touch the glass on the new bulb, it will leave oil off your fingers and will get a hot spot on it causing it to fail.
the bulb has 3 connections on the rear, fit so one is horizontal and the other 2 are verticle,it will locate easier like this.
the rubber cover on the rear has a breather at the bottom fit this way when refitting.
rhino-wayne
Post by rhino-wayne » Thu Dec 15, 2011 8:20 pm
Doesn't take long....try the passenger side 1st (more hand room)...if your a club member there is a fact sheet to help.
aitch
Location: in a place far, far away, well Somerset for now!!!
Post by aitch » Thu Dec 15, 2011 8:46 pm
if you don't ask you will never find out how to do things - so don't apologise just enjoy the fact that people on this forum share their knowledge and we all learn from other know-how.
Post by francophile1947 » Thu Dec 15, 2011 8:48 pm
I've always found it easier to remove the headlamp - it's a simple job :D
Bogmonster40
Post by Bogmonster40 » Fri Dec 16, 2011 10:33 pm
Now your scaring me !!! remove the headlamp !! Am i right in thinking the rubber on the back of the light just pops off to give me access to the light, then i just remove the old one and pop the new one in its place :?:
Post by Northern Bongolow » Fri Dec 16, 2011 10:55 pm
Bogmonster40 wrote:Now your scaring me !!! remove the headlamp !! Am i right in thinking the rubber on the back of the light just pops off to give me access to the light, then i just remove the old one and pop the new one in its place :?:
gently wiggle the multiplug untill it lets go, then remove the rubber doughnut by pulling it, this exposes the rear of the bulb which is held in place by a spring which hooks round a loop, push in the spring towards the bulb, unhook it and swing away, take note of which way it sits (the three terminals) gently pull the bulb, note the 3 locators on the bulb edge that locate it the correct way up in the lamp.
Driver+Passengers
Post by Driver+Passengers » Thu Jan 12, 2012 3:16 pm
With MOT tomorrow, this thread was just what I was after. Thanks.
I put a page on the wiki, too.
Image Image
