can anyone help me with detailed instructions on how to replace the original kmh speedo dial / fascia with a new mph dial - thanks.
Phil
Replacing Speedo dial - help
Re: Replacing Speedo dial - help
Lower the steering column
remove 4 screws holding plastic black facia
unclip the plastic cover over dials
http://www.igmaynard.co.uk/bongo/forum/ ... AL#p394365
then as per pictures in their
remove 2 screws and assuming its an overlay slip it over the old one
After lowering the steering column, I would be inclined to remove the top part of the steering cowl... It just unclips..!
They can get scratched by dial surround when pulled forward..?!
Where roughly in Bristol are you Philipino?
