Roof Problems
maxi_77
Roof Problems
Post by maxi_77 » Thu Nov 24, 2011 7:05 pm
Two problems,
one - several screws at the rear of the roof have pulled out of the plastic moulding. Should I fill with epoxy drill and rescrew, or try the next size up.
two - the fly screen material has torn and seems to be past it's best. I presume the only answer is to remove the thent and get new mozzy material fitted.
White diesel Bongo
Re: Roof Problems
Post by Doone » Thu Nov 24, 2011 7:21 pm
Heres a link with lots of advice on HOW TO GLUE THE SCREWS FOR THE ROOF TENT.
If the net is beyond repair, you can either remove it permanently or replace it, HERE'S A LINK THAT SHOULD HELP.
maxi_77
Re: Roof Problems
Post by maxi_77 » Fri Nov 25, 2011 6:39 pm
Thanks for, one thing whilst the top screws are as stiff as others hav found the bottom ones just turn but do not come out, any thoughts?
White diesel Bongo
Re: Roof Problems
Post by g8dhe » Fri Nov 25, 2011 11:07 pm
I found I needed to lift the threaded portion, whilst holding the outer part down otherwise the whole scrivet turns and you get no where, Can't remember exactly but I think I just used a small screwdriver inserted under the lip to lift the central screw/rivet and hold the outer in a fixed position.
