replacement wheels
Gmac
replacement wheels
Post by Gmac » Tue Nov 22, 2011 10:09 pm
Can anyone suggest alternative alloy wheels to fit to my bongo to replace a buckled one... I've been told that Ford Mondeo wheels are fine.. :?
kloonsy
Re: replacement wheels
Post by kloonsy » Tue Nov 22, 2011 10:23 pm
Gmac wrote:Can anyone suggest alternative alloy wheels to fit to my bongo to replace a buckled one... I've been told that Ford Mondeo wheels are fine.. :?
Mondeo no good. Are they steel? or alloy? If steel, plenty of bongo's getting broken
Dave
The Bongo Bodyshop - For all your Bongo Bodywork needs.
07584 134811
Advice is free.
Gmac
Post by Gmac » Tue Nov 22, 2011 11:17 pm
Alloys Dave, 1 front one buckled so i might have to get whole set, i think it's recommended to have wider tyres on back though..?
Post by Bob » Wed Nov 23, 2011 12:27 am
Loads on tyre sizes if you try a search.
Original equipment is wider, but lower aspect ratio, on rear, but the same (larger) size all round is fine.
If its 4wd the same circumference is vital.
And welcome aboard. :D
Post by Northern Bongolow » Wed Nov 23, 2011 1:24 am
hyundai tuscan 16 inch but correct fitting.
mister munkey
Post by mister munkey » Wed Nov 23, 2011 1:25 am
I have a set of 4 good condition 15" Mazda alloys fitted with four new tyres up for grabs.
PM me if you're interested.
steveyd
Post by steveyd » Wed Nov 23, 2011 12:30 pm
I put a set of Mitsubishi Outlander 16" Alloys on mine - no spigot rings needed and perfect fit. If you are going from steels, you'll need new wheel bolts with a shim on - Toyota ones are fine.
cheers,
Steve
Gmac
Post by Gmac » Wed Nov 23, 2011 3:16 pm
I've just found out that I need wheels to fit Tyres that are 215/65 15..
