BMW Clock new bulb?
Dogran
BMW Clock new bulb?
Post by Dogran » Sat Oct 29, 2011 5:45 pm
Recently purchased a bmw clock from ebay to fit in the Bongo - all good except the light doesn't work. Does anyone know where I can source a replacement bulb? Looked on ebay but couldn't see anything suitable - as i understand it the bulb and its holder do not come apart so have to be replaced as one unit.
Anyone any ideas?
dandemann8
Re: BMW Clock new bulb?
Post by dandemann8 » Sat Oct 29, 2011 7:23 pm
PM Haydn as he's the whizz on these little babie's :wink:
Bongo no more........... ;-(
Post by haydn callow » Sat Oct 29, 2011 7:32 pm
http://www.ebay.co.uk/itm/350229172397? ... 1439.l2649
These are the ones....you can buy just 2.
If when you fit one it dosn't work....remove and rotate 180 degrees....they are LED's so are polarity sensitive.
rhino-wayne
Post by rhino-wayne » Sat Oct 29, 2011 10:00 pm
I like this forum! :D
You mean all this time I just had to buy a bulb! I thought the clock was light-less as standard :lol: :oops: :lol: :oops:
These: "2 Red 509T Twist-Lock LED Dash Dashboard Speedo Bulbs" (Item number: 250903873627) should match my temp' gauge colour scheme :wink:
Post by haydn callow » Sat Oct 29, 2011 10:07 pm
STOP !!!! your BMW clock already has a red filter built in.....all you need is a clear bulb and it will glow red.......putting a red bulb in will just give you a "dimmer" red.......if you want it to glow any other colour including clear then you have to pull the clock to bits and remove the filter.....(suggest you don't try that)
Dogran
Post by Dogran » Sun Oct 30, 2011 7:22 pm
Thanks Hadyn, much appreciated. I've ordered 2 clear 509T bulbs so should be sorted.
nigelgibson
Post by nigelgibson » Sun Oct 30, 2011 9:55 pm
haydn callow wrote:STOP !!!! your BMW clock already has a red filter built in.....all you need is a clear bulb and it will glow red.......putting a red bulb in will just give you a "dimmer" red.......if you want it to glow any other colour including clear then you have to pull the clock to bits and remove the filter.....(suggest you don't try that)
my clock is lit green - what do i need to change it to blue ? Has someone already dismantled it to change from red ?
Post by haydn callow » Sun Oct 30, 2011 11:22 pm
You just need to put a new blue LED bulb in....the filter must have been removed....where did you get it from ??
nigelgibson
Post by nigelgibson » Mon Oct 31, 2011 12:16 am
Thanks Haydn , i bought it off ebay ages ago from a guy advertising them as green backlight to match bongo lights, i guess he must have altered them if the norm is red. I have since added some blue leds so fancied matching things up !
rhino-wayne
Post by rhino-wayne » Mon Oct 31, 2011 12:39 am
Thx Haydn =D> will order some standard white light bulbs rather than coloured :D
Tidmo
Post by Tidmo » Tue Nov 01, 2011 1:51 pm
Hi, my clock still has the red background colour, can i change it to green?
Pourquoi Pas?
Post by haydn callow » Tue Nov 01, 2011 5:36 pm
you will have to pull the clock to bits and remove the red filter....then fit a green LED bulb
or
Send it to me
mikeWalsall
Post by mikeWalsall » Tue Nov 01, 2011 5:45 pm
LEDs are general better .. but usually 'normal' tungsten 509T dash panel bulbs should be available from any car shop ..with or without the plastic base ..
TerryG
Post by TerryG » Wed Nov 02, 2011 10:38 am
I can strongly recommend these people for LEDs. Good prices, next day delivery, clear instructions and advice:
http://www.ultimatemods.co.uk/
'Enjoy every sandwich'
fatcatlawyer
Post by fatcatlawyer » Wed Nov 02, 2011 10:52 am
This thread reminds of that wonderful scene in Red Dwarf. "We should go on to red alert"
"Do we really have to - it will mean changing the bulb"
Classic!
ian G
