Electric Windows
Electric Windows
Post by haydn callow » Wed Oct 26, 2011 7:22 pm
Suddenly both electric windows have stopped working......fuse 14 (30amp) is o.k. and all wireing seems o.k....before I start pulling switches out/apart....is there anything else I should check ??
dave_aber
Re: Electric Windows
Post by dave_aber » Wed Oct 26, 2011 7:37 pm
If you pop the switch out of the driver's door, disconnect the plug and check for 12v between the 2 feed cores in the plug - they are the bigger wires in there.
IIRC, the +12v is the black core with the red line on it. You should have 12v on this with the ignition on.
If you have 12v there, you might have an issue with the switch.
Image...Image
Post by francophile1947 » Wed Oct 26, 2011 7:54 pm
When that happened to me, it was the thick black wire in the loom between the driver's door and frame. I had to remove the black plastic sleeve from the loom to actually discover it.
Post by haydn callow » Wed Oct 26, 2011 8:12 pm
Wife away in Bongo tomorrow till Sunday.
Will check those suggestions out next week
jaylee
Post by jaylee » Wed Oct 26, 2011 8:55 pm
francophile1947 wrote:When that happened to me, it was the thick black wire in the loom between the driver's door and frame. I had to remove the black plastic sleeve from the loom to actually discover it.
With Johns idea, but if not apparent....
The black earth wire as it goes under the cowl/sheathing in the wing from the door up from the V to the door hinge..? (I've seen it on a few, including mine!) :idea:
