Safety beeping alarm noises
Printer
Post by Printer » Sun Oct 09, 2011 12:02 am
Hi all
The previous owner had all the beeping noises turned off as he didnt like the reversing safety. however, now I keep leaving my lights on so Im thinking of getting the mechanic to rewire them in. Is this easy to do, is there a fact sheet?
Also, SHOULD I do this or is there loads of annoying ones and it is better without them??
What safety alarm beeping noises are there if I turn them back on? Have any of you done this?
Re: Safety beeping alarm noises
Post by g8dhe » Sun Oct 09, 2011 10:46 am
If all the Beeps are gone then most likely the previous owner has just disconnected the entire module, in which case plug it back in! Its located down in the drivers offside footwell behind the plastic trim by the door. Its also possible that they just put a pair of cutters thru some of the wires, in which case you will need to rejoin colour for colour.
Once you have restored the beeps then a lot of the most annoying Beeps can be removed by disconnecting the "Key In" switch at a connector under the steering coloumn here;
Velocette
Post by Velocette » Sun Oct 09, 2011 10:49 am
It is the ignition key in with door open one that is the biggest PITA for me, mainly when camping.
PisceanJoy
Post by PisceanJoy » Sun Oct 09, 2011 10:57 am
Didnt realise you could disconnect the key in one
i feel a visit to worthing coming on!
Post by g8dhe » Sun Oct 09, 2011 12:45 pm
Shout next time your coming over Joy, its normally a 5 minute job, unless that cable has been pushed right to the back of the cable form!
PisceanJoy
Post by PisceanJoy » Sun Oct 09, 2011 2:16 pm
great ta
Diplomat
Post by Diplomat » Sun Oct 09, 2011 6:23 pm
I found that the best solution was to quieten it rather than disconnect it.
A piece of broken matchstick poked into the sounder's orifice did the trick.
Reduced it by quite a few dBs but still get the warnings.
Frank
They flew, I took up naturism
