Rev Counter (V6)
Major Grump
Rev Counter (V6)
Post by Major Grump » Mon Sep 26, 2011 4:27 pm
Hi All,
I'm new to Bongo's and have only just got mine back after an overheating issue. When I drove it home the rev counter was showing ~4000rpm at 105kph, this seems at lot to me (I'm used to a modern diesel where 4000 rpm would be really caning it!). Can someone tell me if this is normal? The rev counter didn't work when I got it so it may still be broken or this may be normal!
Thanks,
James
dandemann8
Re: Rev Counter (V6)
Post by dandemann8 » Mon Sep 26, 2011 7:19 pm
Hi, from memory mine sits at 2500 to 3000rpm at 65-70mph with the cruise control on :wink: :D
Bongo no more........... ;-(
New Forest Terrier
Post by New Forest Terrier » Mon Sep 26, 2011 7:58 pm
My V6 would only rev that high if being really hammered up a steep hill.
I would agree with danderman about 2500 at 60-65mph. I try to keep it around this figure because this returns the best fuel economy.
Post by haydn callow » Mon Sep 26, 2011 8:11 pm
you didn't press the HOLD button did you ??
Major Grump
Post by Major Grump » Tue Sep 27, 2011 9:01 am
haydn callow wrote:you didn't press the HOLD button did you ??
I'll check the hold button but I don't think so.
Okay, so either the rev counter is wrong (hopefully) or the gearbox is playing silly buggers. It doesn't sound like its revving like mad and if I stomp my foot down I can feel it change up so I assume its in the right gear.
While I'm on the subject... can someone explain the S gear and L(?). I assume these are sport and Low but haven't used them.
Thanks.
Luke and Debs
Post by Luke and Debs » Tue Sep 27, 2011 9:19 am
my v6 revs at 2500rpm at 60 mph and 3000 at around 72 mph.
the s gear is a low ratio gear for when coming down steep hills as it will only hold the first two gears and not let the van run away. also the L gear is even lower for even steeper hills. think this just holds it in the first gear. like wise u could use the hold button to keep it in gears.
Luke (V6 and LOVING IT)
Post by missfixit70 » Tue Sep 27, 2011 1:40 pm
Using the gearbox - http://www.igmaynard.co.uk/bongo/forum/ ... =3&t=38644
Major Grump wrote: It doesn't sound like its revving like mad and if I stomp my foot down I can feel it change up so I assume its in the right gear.
It changes down, not up when you "stomp your foot", try, "not stomping your foot" & accelerate gently, it should stay in lock up & the revs should be a bit lower & economy better :wink:
Major Grump
Post by Major Grump » Wed Sep 28, 2011 8:07 am
missfixit70 wrote: It changes down, not up when you "stomp your foot", try, "not stomping your foot" & accelerate gently, it should stay in lock up & the revs should be a bit lower & economy better :wink:
Okay, fair point, down not up! 8)
I do generally drive 'gently', the Bongo isn't exactly a racing car after all! I suspect the rev counter is simply off, its just proving it that is difficult.
