AFT roof struggling to open fully
Roof is struggling to open fully recently. Gets about 80-90% of the way up and then either fails to complete or jerks slowly almost into position doing lots of creaking and juddering. No problems on the way down. Any ideas?
						Re: AFT roof struggling to open fully
Probably wants greasing in the runners - up inside the roof.  Maybe you could spray them, but I got my hand up and spread dollops of grease along the runners.  Awkward and messy but it did the trick - my roof lifted a lot smoother after that.
						- daveblueozzie
If you can, use silicon spray grease it wont hold the dirt like ordinary grease.
My roof does the same, it sometimes needs a helping hand pushing up from inside to make it fully open.
Lost without my Bongo.
Are you runnning the engine when raising the roof?
What he said!daveblueozzie wrote:If you can, use silicon spray grease it wont hold the dirt like ordinary grease.
						- gmaczbongo
Hold up button and give it a wee push to help it.
We all need a helping hand sometime.
Level ground is a must for mine or it gets stuck, just like yours.
				gill+berniebann
must admit i give ours a helpin hand the motors r 16 \years old
- mikexgough
yep.... a decent Silicon spray is the best way.....plus get yer roof up at least monthly...bigdaddycain wrote:What he said!daveblueozzie wrote:If you can, use silicon spray grease it wont hold the dirt like ordinary grease.
