Diesel 4x4 auto air-con tensioner question
def_fid
Post by def_fid » Wed Aug 24, 2011 4:01 pm
Just completed a round trip of Scandinavia, 4280 miles in 3 weeks. Nothing went wrong. Used 200ml of oil. Averaged 28mpg. :D However the alternator belts needed adjustment and the aircon belt is chirping under load. Should I replace the tensioner wheel when I replace the aircon belt, or does it just need a bit of oil?http
Re: Diesel 4x4 auto air-con tensioner question
Post by missfixit70 » Wed Aug 24, 2011 5:12 pm
Probably just needs the pulleys deglazing & new belts, as long as all the pulley bearings are ok.
Kincaid
Post by Kincaid » Wed Aug 24, 2011 6:07 pm
missfixit70 wrote:Probably just needs the pulleys deglazing & new belts, as long as all the pulley bearings are ok.
Hi - to test the bearings do you need to remove the belts - or just drop the tension on them?
Bongo Gymreig
