Tyre sizes
mark.hingston
Tyre sizes
Post by mark.hingston » Sat Jul 30, 2011 6:27 pm
Hi, I have 195's on the front and 215,s on the back, as stated in the handbook, But the tyres have become castleated on the front, and making a lot of noise. I have been in touch with Allens garage in Devon and he tells me that I should change the tyres and have them all the same size. Does that mean I should have four 215's fitted? Why does the hand book state different size tyres if it is not so. :(
Mark and Julie
1998 Aquamarine Ford Freda
2.5td 4wd aft
Re: Tyre sizes
Post by rita » Sat Jul 30, 2011 6:55 pm
mark.hingston wrote:Hi, I have 195's on the front and 215,s on the back, as stated in the handbook, But the tyres have become castleated on the front, and making a lot of noise. I have been in touch with Allens garage in Devon and he tells me that I should change the tyres and have them all the same size. Does that mean I should have four 215's fitted? Why does the hand book state different size tyres if it is not so. :(
Hi mark.hingston,
The hand book is correct with the designed tyre sizes for this vehicle,the garage is giving you there opinion of what can be used,as other owners have done.Its up to you what road you take(excuse the pun) :) .
Cheers..
iBongo
Re: Tyre sizes
Post by iBongo » Sat Jul 30, 2011 7:11 pm
I have pretty much the same question. Could you please explain what the numbers mean #-o
all my Tyres are the same size. 215/65 R15 100H XL I have NO idea what any of the numbers mean, sorry :oops:
Can I go out and buy any 15 inch alloy and use my tyres....??
Re: Tyre sizes
Post by missfixit70 » Sat Jul 30, 2011 7:20 pm
birdiegolf wrote:Can I go out and buy any 15 inch alloy and use my tyres....??
- yes, if the wheels are rated high enough for the bongo & fit ok.
This FAQ may help point you in the right direction - http://www.igmaynard.co.uk/bongo/forum/ ... =43&t=7895
Re: Tyre sizes
Post by g8dhe » Sat Jul 30, 2011 7:21 pm
I won't get into discussing tyre sizes but there is a good explanation on Wikipedia http://en.wikipedia.org/wiki/Wheel_and_ ... _they_mean of what the numbers mean just look at the pictures on the right to start with ;-)
iBongo
Re: Tyre sizes
Post by iBongo » Sat Jul 30, 2011 7:32 pm
Brilliant, thanks :D
