crankshaft oil seal
M 80NGO
- Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
crankshaft oil seal
Hi guys, i have a little oil leak from my crankshaft oil seal, have any of you guys had this seal replaced on your van , if so what sort of ££££ did it cost to do ?
Thanx, Pete.
Thanx, Pete.
Re: crankshaft oil seal
front or back.
flossie
- Tribal Elder
... and girls ??
Um well the good news is the part is cheap as I remember maybe 10 or £15 .... the bad news is it's pretty much a full day of labour to strip down and get to it ... I had to have mine done about 6 months ago. There are two other seals in the same area ... cam shaft possibly ? and they are about£8 each so get them replaced at the same time ...
Liz
'99 V6 White over Silver - as yet unconverted but I may be converted!
Hi,flossie wrote:... and girls ??![]()
I think M Bongo is reffering to a 2.5 diesel engine.
Cheers.
M 80NGO
hi and thanx for the input, its a 2.5TD and its the front seal thats leaking
Not read on here of this happening to a diesel before. Would Steve at Outback Motors be a good person to ask?M 80NGO wrote:hi and thanx for the input, its a 2.5TD and its the front seal thats leaking
flossie
- Tribal Elder
rita wrote:Hi,flossie wrote:... and girls ??![]()
I think M Bongo is reffering to a 2.5 diesel engine.![]()
Cheers.
Yes but surely its in more or less the same place so not a quick job?
Liz
M 80NGO
From what i've seen it looks like remove aircon radfan, loosen alternator, remove crankshaft pulley to gain access to the oilseal i'll ring bellhill tomorrow and ask the question while ordering a seal kit
- bongodonkey
- Tribal Elder
For interest of V6 ers
£540 of labour @ £45 per hour and I got one mail order with 24hr delivery for £45. I was in a bit of a bind as we were up in Scotland on holiday in Feb...........
Absolute treat.....hope the diesel is a much kinder bill....
Oz, Sam & the girls | 2001 V6 AFT | LPG | 321Away F/S/C | A Bongo called OLIVE
if you have a pit it should be ok,shouldnt need to touch the aircon fans,may remove scavenger fan if you need a bit more room.M 80NGO wrote:From what i've seen it looks like remove aircon radfan, loosen alternator, remove crankshaft pulley to gain access to the oilseal i'll ring bellhill tomorrow and ask the question while ordering a seal kit
watch the crank pulley, if you pull it wrong it could seperate as its bonded together,grip it from the rear not on the belt grooves. then like you say straight forward job.
M 80NGO
Northern Bongolow wrote:if you have a pit it should be ok,shouldnt need to touch the aircon fans,may remove scavenger fan if you need a bit more room.M 80NGO wrote:From what i've seen it looks like remove aircon radfan, loosen alternator, remove crankshaft pulley to gain access to the oilseal i'll ring bellhill tomorrow and ask the question while ordering a seal kit
yep i thought as much, it'll be going in to have the job done and while they have it they can do an oil and filters change to to save me having the mess, glad i havn't got a leaky V6 tho that sounds a little more indepth and having just paid out £430 to have the diesel pump removed refirbed and refitted i really don't need another huge bongo bill
flossie
- Tribal Elder
OUCH - did u get it done at a Ferrari garage ? Mine was expensive but no where near that cost !!!bongodonkey wrote:For interest of V6 ers
Liz
M 80NGO
Just as a matter of interest where does the cam belt take its drive from ?
fuel pump.which is driven by internal gear/woodruff key drive from the crank.
- dandywarhol
Also look for a cause of the seal leak - could be the breather pipe from the camcover is kinked or blocked, or the filter mesh inside the camcover is blocked. If the system isn't breathing properly the new seal will pop too.
