crankshaft oil seal
M 80NGO
Location: Usually in My own wibbly wobbly lill world ! Otherwise Huntingdon.
crankshaft oil seal
Post by M 80NGO » Sat Jul 23, 2011 10:19 pm
Hi guys, i have a little oil leak from my crankshaft oil seal, have any of you guys had this seal replaced on your van , if so what sort of ££££ did it cost to do ?
Thanx, Pete.
Re: crankshaft oil seal
Post by Northern Bongolow » Sat Jul 23, 2011 11:53 pm
front or back.
flossie
Post by flossie » Sun Jul 24, 2011 8:15 am
... and girls ?? :)
Um well the good news is the part is cheap as I remember maybe 10 or £15 .... the bad news is it's pretty much a full day of labour to strip down and get to it ... I had to have mine done about 6 months ago. There are two other seals in the same area ... cam shaft possibly ? and they are about£8 each so get them replaced at the same time ...
Liz
'99 V6 White over Silver - as yet unconverted but I may be converted!
rita
Post by rita » Sun Jul 24, 2011 11:21 am
flossie wrote:... and girls ?? :)
I think M Bongo is reffering to a 2.5 diesel engine. :)
Cheers.
M 80NGO
Post by M 80NGO » Mon Jul 25, 2011 5:32 am
hi and thanx for the input, its a 2.5TD and its the front seal thats leaking :wink:
Post by mikeonb4c » Mon Jul 25, 2011 2:15 pm
M 80NGO wrote:hi and thanx for the input, its a 2.5TD and its the front seal thats leaking :wink:
Not read on here of this happening to a diesel before. Would Steve at Outback Motors be a good person to ask?
flossie
Post by flossie » Mon Jul 25, 2011 4:48 pm
Cheers.
Yes but surely its in more or less the same place so not a quick job?
Liz
M 80NGO
Post by M 80NGO » Mon Jul 25, 2011 7:14 pm
From what i've seen it looks like remove aircon radfan, loosen alternator, remove crankshaft pulley to gain access to the oilseal i'll ring bellhill tomorrow and ask the question while ordering a seal kit :wink:
bongodonkey
Post by bongodonkey » Mon Jul 25, 2011 9:25 pm
For interest of V6 ers
£540 of labour @ £45 per hour and I got one mail order with 24hr delivery for £45. I was in a bit of a bind as we were up in Scotland on holiday in Feb...........
Absolute treat.....hope the diesel is a much kinder bill....
Oz, Sam & the girls | 2001 V6 AFT | LPG | 321Away F/S/C | A Bongo called OLIVE
Post by Northern Bongolow » Mon Jul 25, 2011 10:05 pm
M 80NGO wrote:From what i've seen it looks like remove aircon radfan, loosen alternator, remove crankshaft pulley to gain access to the oilseal i'll ring bellhill tomorrow and ask the question while ordering a seal kit :wink:
if you have a pit it should be ok,shouldnt need to touch the aircon fans,may remove scavenger fan if you need a bit more room.
watch the crank pulley, if you pull it wrong it could seperate as its bonded together,grip it from the rear not on the belt grooves. then like you say straight forward job. =D>
M 80NGO
Post by M 80NGO » Tue Jul 26, 2011 5:30 am
yep i thought as much, it'll be going in to have the job done and while they have it they can do an oil and filters change to to save me having the mess, glad i havn't got a leaky V6 tho that sounds a little more indepth and having just paid out £430 to have the diesel pump removed refirbed and refitted i really don't need another huge bongo bill :roll:
flossie
Post by flossie » Tue Jul 26, 2011 7:03 am
bongodonkey wrote:For interest of V6 ers
OUCH - did u get it done at a Ferrari garage ? Mine was expensive but no where near that cost !!!
Liz
M 80NGO
Post by M 80NGO » Tue Jul 26, 2011 5:23 pm
Just as a matter of interest where does the cam belt take its drive from ?
Post by Northern Bongolow » Tue Jul 26, 2011 6:16 pm
fuel pump.which is driven by internal gear/woodruff key drive from the crank.
dandywarhol
Post by dandywarhol » Wed Jul 27, 2011 12:33 am
Also look for a cause of the seal leak - could be the breather pipe from the camcover is kinked or blocked, or the filter mesh inside the camcover is blocked. If the system isn't breathing properly the new seal will pop too.
