Air Con Problem
TechnoTurkey
Air Con Problem
Post by TechnoTurkey » Sun Jul 10, 2011 11:18 am
My air con seems to have packed up, the light on the ac button comes on when you press it but I don't hear the fan come on and no cold air comes.
I've checked the fuse and it is fine, what should I be trying next?
Thanks in advance.
Member 10,000!
1997 Green AFT 4x4 2.5TD Auto Bongo
Re: Air Con Problem
Post by g8dhe » Sun Jul 10, 2011 11:27 am
I would suggest the usual motor problem or resistor pack / speed controller.
The motor problem being water ingress that seizes it up eventually, from overflowing the window screen waste pipe that gets blocked.
The resistor pack (Manual control) / speed controller (Electronic controller) blowing from the same problem above when the current rises.
There is a fact sheet on the likely repairs http://www.igmaynard.co.uk/bongo/member ... sistor.pdf
Re: Air Con Problem
Post by teenmal » Sun Jul 10, 2011 11:40 am
TechnoTurkey wrote:My air con seems to have packed up, the light on the ac button comes on when you press it but I don't hear the fan come on and no cold air comes.I've checked the fuse and it is fine, what should I be trying next?
Thanks in advance.
What fan? if its the one on the radiator you will probably need the system regassed.
Cheers.
Re: Air Con Problem
Post by missfixit70 » Sun Jul 10, 2011 12:11 pm
Re: Air Con Problem
Post by Doone » Sun Jul 10, 2011 12:51 pm
They do stop working (safety cut-out) when the gas gets too low, has it been filled recently?
TechnoTurkey
Re: Air Con Problem
Post by TechnoTurkey » Sun Jul 10, 2011 4:30 pm
Thanks everyone, I've got a mate who can regas it so I'll go down that route first.
The blowers blow but the rad fan doesn't kick in....
Member 10,000!
