  ).  LBs like to have a full charge from a 240v device every 3 months or so, and it occurs to me that those who cannot park up somewhere where they can run an extension lead out to the car, may have a problem with this. Taking an LB out and dragging it indoors every 3 months is a pain.
What I am wondering is whether a 240V charger (I have the Aldi bargain offer version of the C-Tek type charger) could be used to give my LB the full charge it likes to have at intervals, but that (I understand) it can’t get from the 12v charging system.
It seems to me that this idea won’t work if the inverter is working off the battery it is trying to charge, so it would need to be running off the starter battery. Also, I don’t like the idea of the LB taking charge through the onboard 12v charging facility (I’ve just fitted the wonderful Willinton charging kit at the same time as fitting the Energy Bull) whilst also attempting to receive charge from the 240v charger (I’m not sure what unpredictable effects might result).
So, what if the 240v inverter ran off the starter battery (in reality it will effectively be running off the alternator and not draining the SB once the engine is running). And what if a breaker switch was fitting into the +ve to +ve connection from SB to LB so the LB could be isolated when it is receiving a charge from the 240v charger. You might then use time when you are running around in the Bongo, but not camping, to charge the LB.
You could argue then: why bother with a 12v charging setup at all. I guess the answer is that an inverter wastes power running itself before it even delivers power to the 240v charger, so it is inefficient and not a good idea for normal charging.
As regards the switching arrangements, I can think of al kind of fancy things that could be made to work by the flick of a switch: swapping 240v charge and inverter powering around so either LB or SB could receive a conditioning charge; switching on the inverter at the same time, and hard wiring the charger from inverter to battery(s) etc. etc.
But is all this nuts? I’d be interested to get the thoughts of anyone knowledgeable about this kind of electrical stuff.
You have the floor
 ) that it's a bit academic for me.  Still a sensible idea though (must fit a suitable 240v socket for hookup on site - where's a good place?)
