Advice needed please.
georgey
Post by georgey » Wed Apr 27, 2011 11:46 am
Thinking of buying a 2.5 mt Fiamma 35 awning and VW T3 fixing brackets for my Tintop will this fit ok? Any advice welcomed and appeciated. Thanks Geoff.
Re: Advice needed please.
Post by haydn callow » Wed Apr 27, 2011 1:00 pm
I used those fixings on my Fimma and to be honest they tend to vibrate a LOT when on slow tickover and when switching off the engine.....I was afraid the gutter would suffer.....so !! as mine was a ATF at the time I put extra brackets from the "under AFT" awning mounting brackets......I now have a tintop and knowing what I now do I would go for a really lightweight caravanstore or somthing along those lines.
Just had a good look at the 35....it does seem a bit lighter than the one I had so you may get away with it......
georgey
Post by georgey » Wed Apr 27, 2011 1:42 pm
Thanks Haydn. Think the 35 is 9kg and the 45 is 18kg...
madmile
Post by madmile » Wed Apr 27, 2011 7:27 pm
The trick Geoff, is to bend and manipulate the brackets so that they sit square and parallel to each other, but also so they have a bit of tension against the side of the van.
If your passing, pop in and I will show you what I mean - if you call over on a saturday(not this saturday though) we may even help you do it :wink: .
georgey
Post by georgey » Wed Apr 27, 2011 11:39 pm
thanks Ed. I'll give you a ring.
Post by Bob » Wed Apr 27, 2011 11:43 pm
Great support from a Forum Member. =D>
