Advice on which oil to use? V6
bessthebongo
Post by bessthebongo » Fri Apr 01, 2011 12:07 pm
Hi everyone......
Been using my bongo a lot in this pass week traveling around 120 miles a day... am looking at topping up my oil but unsure on which one to use. I have a V6 Tintop petrol 1998 S reg.
Please could you help...
Many thanks.
8)
bongobev
Re: Advice on which oil to use? V6
Post by bongobev » Fri Apr 01, 2011 10:20 pm
bessthebongo
Post by bessthebongo » Fri Apr 01, 2011 10:48 pm
Thanks very much for the info bongobev.
:D
Post by Bob » Fri Apr 01, 2011 10:53 pm
I've an idea there was a Fact Sheet on oil.
You really need to top up with whatever is already in there as oils aren't always compatible and can cause frothing and block oilways.
Since the oil change is fairly frequent, with the kind of mileage you're doing it may be worth changing the oil then keeping some to top up.
Edit: I suspect the frequency may be less with a V6 petrol than a turbo diesel, but I'd still just change it and keep some of the same to top up.
A Pela Pump makes oil changes a piece of cake.
321Away
Post by 321Away » Mon Apr 04, 2011 2:26 pm
Your right Bob, if the service interval for petrol cars was 3000 we'd never get anywhere! Even for a turbo diesel its a bit ott, with modern oils its a lot more than 3000 miles, at 321 they have their lubricants made to spec, including engine,transmission and diff, all very technical and there are lots of sheets of data for each type and why its better than that brand etc sure its interesting to someone lol
Curious from that link why they push for 10/30 and say 'you could get away with 10/40'?
Julian
