Missing bits
Missing bits
Hi can anyone tell me what is missing from the front of the heater intake.It was like this when i bought it but did not notice.hasnt caused any problems but would be good to replace it.
						Re: Missing bits
Yep you`ve got the intake missing
looks like
http://www.lushprojects.com/bongopartsm ... o=.html#12
61-820
Hope that helps
						looks like
61-820
Hope that helps
- daveblueozzie
Re: Missing bits
You can see the scoop on top of the radiator thats fits onto the fan intake.
Lost without my Bongo.
						Re: Missing bits
Thanks a lot, has anyone got one lying around or know anyone with one?
						- Flint
 - Bongonaut
Re: Missing bits
Is there meant to be a filter in there?
									The saying “Getting there is half the fun” was penned with a Bongo in mind!
[color=#408040]1996 2.5 D 4x4 AFT[/color]
Re: Missing bits
I don't think there's a filter in the scoop system. I can't believe scoops from breaking Bongos are in great demand so you should be able to haggle for a cheap price for a replacement from breakers like Bellhill. Don't forget you'll need the plastic fastener studs that are used to hold the scoop in place using holes in the front valance where the bonnet front sits.Flint wrote:Is there meant to be a filter in there?
- daveblueozzie
Re: Missing bits
As Mike said no filter in the scoop, and the word Mike is looking for is SCRIVETSmikeonb4c wrote:I don't think there's a filter in the scoop system. I can't believe scoops from breaking Bongos are in great demand so you should be able to haggle for a cheap price for a replacement from breakers like Bellhill. Don't forget you'll need the plastic fastener studs that are used to hold the scoop in place using holes in the front valance where the bonnet front sits.Flint wrote:Is there meant to be a filter in there?
						- mikexgough
Re: Missing bits
The best "scrivets". for the scoop are Citroen/Peugeot ones that they use for the plastic wing liners....as they are slightly "tighter fitting and keep the intake "solid" but are push in centres,I am now waiting arrival of a supply of the same type Mazda use (screw in centre) but for Citroen....so the best of both worlds for those who are concerned about authenticity.
- dreamwarrioruk
Re: Missing bits
ours has never had scrivets in the last 5 yrs, not been a problem
									mike, jo and emma
						- TechnoTurkey
Re: Missing bits
Mine is also scrivet-less.  A couple of zip ties do a perfectly reasonable job, I just carry a few spares in case I need to snip them off.
									Member 10,000!
1997 Green AFT 4x4 2.5TD Auto Bongo
Re: Missing bits
some do have a mesh across the opening to keep the bugs out but most are just open.Flint wrote:Is there meant to be a filter in there?
Re: Missing bits
Thanks Dave - the word escaped me, and I knew it wasn't rivets! So close and yet so fardaveblueozzie wrote:As Mike said no filter in the scoop, and the word Mike is looking for is SCRIVETSmikeonb4c wrote:I don't think there's a filter in the scoop system. I can't believe scoops from breaking Bongos are in great demand so you should be able to haggle for a cheap price for a replacement from breakers like Bellhill. Don't forget you'll need the plastic fastener studs that are used to hold the scoop in place using holes in the front valance where the bonnet front sits.Flint wrote:Is there meant to be a filter in there?![]()
Re: Missing bits
Glad to here nothing major missing but i will try to sorce one asap. If anyone has heard of a company called Wurth who make all sorts of stuff,they make fasteners to match all manufacturers and they are cheaper. If there is a certain type that everyone wants it may be possible to get a box which would work oiut much cheaper than buying OE clips.
						Re: Missing bits
When i got my heater matrix from the scrapyard i found the intake that was missing lying next to the car and got it for free so result.
