Engine Fan Noise Got Louder.
mr and mrs pips
Can anyone help
The fan that cools the engine seems to have got very loud all of a sudden, Does anyone know what causes this, is there a quick fix or a easy but of maintenance, I should be doing ?
I left the van to cool after a drive... started it up and all seems fine usual noises an hummings.
regards Mr P
Can anyone help
regards Mr P
Re: Engine Fan Noise Got Loader.
If your rad fan is coming on in this weather I would get to cooling system checked out.
Cheers.
What vehicle do you have?
Cheers.
Re: Engine Fan Noise Got Louder.
when the fan switch wire is broken,or the plastic end of the switch breaks or is wobbly the fans can come on early.check the switch carefully.
your aircon isnt on is it ??.
mr and mrs pips
Hmm
OK went for a little drive 3 miles ok
6 miles fan kicking in loud and temp reading a little hotter than this pic
Air con was not on,,, and it was -1 outside
Coolent about half full.
If that is an unmodified temp gauge (i.e. Mason alarm not fitted) then I would be very concerned at that needle position. The needle of a healthy gauge sits at the 11.00 oclock position at all times once engine has warmed up. Get the car looked at ASAP I reckon and don't drive it until then if poss.
agree with teenmal and mike on this one.
Dave.
you thermostat may be stuck closed
mr and mrs pips
Well
topped up levels and tested again overheating again, temperature pointer at 2 o clock
so its gone to the garage, There talking about needing a new Gasket Possibly.......
Oh dear, it sounds like Ben's sweetie money is in danger of a reduction
Fingers crossed
mr and mrs pips
Hmm oh dear
Just got told by the garage the gasket has gone, and the engine has been drinking coolent,
and so overheating
As luck would have it 2 glow plugs wont come out so its getting more expensive by the minute....
mr and mrs pips
lazyb5 wrote:Hi,
thats bad news, which garage are you using?
Hopefully a Bongo Friendly One.... or it will be if it does not cause me to loose and arm and a leg.
I use Cartel because i know them, unfortunately due to my Ford being such a piece of c..p. They seem to do a proper job and if not bongo friendly if armed with the correct info would use it. I`m going in there on Thursday with the Ford again I can ask if they know what a bongo is may help you make an informed decision.
mr and mrs pips
It is Cartel we are using, they are very close to use and were recommended to us, just saw the bongo last night when we went to get the Baby Seat out of it.lazyb5 wrote:I use Cartel because i know them, They seem to do a proper job and if not bongo friendly if armed with the correct info would use it. I`m going in there on Thursday with the Ford again I can ask if they know what a bongo is may help you make an informed decision.
ALL in pieces
Getting expensive now reached £1000,88 about half a dozen items needed to repair it.......
hopefully comming home next week.
regards Mr Pips
I was there picking up the ford today they replaced the driveshaft/ gearbox oil seal free of charge. They replaced the driveshaft about 8 weeks ago. It was losing oil so they replaced the seal. With aftercare like that i`ll keep going back.
I spent £1000 last summer on the Ford for a new clutch and dual mass flywheel and then £250 quid on a driveshaft 8 weeks ago, so i guess £1000 on a 15 year old imported car isnt too bad but i can think of other things too spend the money on.
On a positive note at least you`ll have it back for the Rutland water meet in Feb, I also saw a blue over silver AFT driving into peterborough about 10.30 this morning I did wave but was in a red Peugeot.
Hope everything goes well and you are bongoing soon.
