Headlight light problems!
se3454
Post by se3454 » Sun Jan 23, 2011 10:07 pm
Hi, got a problem with my headlights if anyone can help. Sidelights and full beam work fine. Yet if I switch my headlights on they come on then go straight off to just sidelight bulbs. But if I leave my headlights switched on as soon as I start to drive my bongo the headlights come on, until I stop to a standstill at a junction and they then switch off. As they go on an off I can hear a click from what seems like a relay in the driver footwell. Any ideas anybody? Thanks in advance.
westonwarrior
Re: Headlight light problems!
Post by westonwarrior » Sun Jan 23, 2011 11:45 pm
search around the cab on the drivers side and you will find a rocker switch probably by the knees but could be any where
this turns this gizmo on as it stops you dazzling trafic while stopped in traffic popular in japan it seams but not recomended here.
se3454
Post by se3454 » Mon Jan 24, 2011 12:18 am
Found it! Many thanks problem solved. Must of knocked this little switch or something, was dreading it being something expensive! Thanks again
