Headlight light problems!
Hi, got a problem with my headlights if anyone can help. Sidelights and full beam work fine. Yet if I switch my headlights on they come on then go straight off to just sidelight bulbs. But if I leave my headlights switched on as soon as I start to drive my bongo the headlights come on, until I stop to a standstill at a junction and they then switch off. As they go on an off I can hear a click from what seems like a relay in the driver footwell. Any ideas anybody? Thanks in advance.
- westonwarrior
Re: Headlight light problems!
search around the cab on the drivers side and you will find a rocker switch probably by the knees but could be any where
this turns this gizmo on as it stops you dazzling trafic while stopped in traffic popular in japan it seams but not recomended here.
Found it! Many thanks problem solved. Must of knocked this little switch or something, was dreading it being something expensive! Thanks again
