Water in light...... help!
Dizzy-Dots
Post by Dizzy-Dots » Tue Jan 11, 2011 3:19 pm
I've got to take Jonnie for his MOT, but there's water in his passenger side side light/indicator, which causes the indicator and side light to work when it feels like it :? so obviously, he won't get his pass certificate with this problem..... :(
The glass of the light was cracked about a year ago by someone bumping Jonnie when he was parked in a carpark....which is leaking now and letting the water in.....
I really don't want to ask the ar$ehole how to fix it, so can anyone point me in the right direction please? Should I replace the light? and if so, where do I get one? :?
Sorry for being a complete girl! :oops:
Lisa
1995 'N' Plate - 2WD AFT in Black - called 'Jonnie'!
Re: Water in light...... help!
Post by mikeonb4c » Tue Jan 11, 2011 3:29 pm
You probably need to replace it, and someone like Bongobits (or maybe ebygum if he still has one on his breaking Bongo) should be able to oblige with a 2nd hand one. Not especially difficult ot change if you can find a helpful local Bongo owner (or the garage could do it - its only basic stuff).
Good luck
Mike
xx
Dizzy-Dots
Post by Dizzy-Dots » Tue Jan 11, 2011 4:00 pm
D'uh! #-o :oops: Stupid question again.....is the passenger side, the nearside? :oops:
Lisa
jaylee
Post by jaylee » Tue Jan 11, 2011 4:02 pm
Dizzy-Dots wrote:D'uh! #-o :oops: Stupid question again.....is the passenger side, the nearside? :oops:
Yes... Have you found the part?
Dizzy-Dots
Post by Dizzy-Dots » Tue Jan 11, 2011 4:04 pm
Think so....... [-o<
Lisa
Dizzy-Dots
Post by Dizzy-Dots » Tue Jan 11, 2011 4:06 pm
I've bought this - please say it's the right one.......
ebay item number..... 200507703169
Lisa
jaylee
Post by jaylee » Tue Jan 11, 2011 4:07 pm
Fair enough... Bellhill do em if yer stuck! :idea:
Dizzy-Dots
Post by Dizzy-Dots » Tue Jan 11, 2011 4:09 pm
Think that's who I've bought it from? At least I think it is.....? #-o
Lisa
Post by Muzorewa » Tue Jan 11, 2011 4:09 pm
Yep, looks right :wink:
jaylee
Post by jaylee » Tue Jan 11, 2011 4:10 pm
Dizzy-Dots wrote:I've bought this - please say it's the right one.......
Looks like the right one!! =D> You got it from the Bellhill people too... :wink:
Dizzy-Dots
Post by Dizzy-Dots » Tue Jan 11, 2011 4:11 pm
Yay me! :D Be prepared for more questions when it gets here......
.....thanks guys :D
Lisa
New Forest Terrier
Post by New Forest Terrier » Tue Jan 11, 2011 10:56 pm
Probably too late now you have ordered a light, but I have had very good results with Capt Tolleys Creeping Crack Remedy on a cracked Bongo rear light. This seals cracks in plastic, fibreglass, glass, concrete almost anything. It gives a completely watertight seal and is permanent. It's a liquid that is trickled into the crack until it is sealed. After about half an hour it dries clear and other layers can be added if necessary till all is fixed.
As well as the Bongo I have used it on a stone chip on my caravan window. Again total success. Mine came from towability, but most caravan shops or ships chandlers stock it. At £6.99 it is a lot cheaper than a new lens. I dried out the interior of the light where there was some condensation and all is fine. This was two years and two MOT's ago, no further problems. =D>
helen&tony
Post by helen&tony » Wed Jan 12, 2011 6:42 am
I second that on the Captain Tolleys...I've used it a few times over the years on caravans....currently on a rear light lens on the Bongo, until I send for a new one...and sealing the washer jets to the bodywork....TOP STUFF
Dizzy-Dots
Post by Dizzy-Dots » Wed Jan 12, 2011 7:35 am
Have noted the name of that stuff - always good to know - thanks :)
Lisa
Dizzy-Dots
Post by Dizzy-Dots » Thu Jan 13, 2011 6:09 pm
Jonnie's new light was delivered today.... :D
Now then, what do I do to fit it? :?: Bearing in mind, I'm a complete girl :roll: :oops:
....and why is it raining so much when it needs to be fitted! :?
Lisa
