Sliding door stuck - relays?
anfarrow
Post by anfarrow » Sun Jan 09, 2011 12:29 am
My sliding door is jammed shut. I've read the fact sheet but still can't get it open. Looking at the fuse box, I am surprised that it's a fuse and not a relay for this.
Can I confirm there is definitely no relays involved in the soft close mechanism?
westonwarrior
Re: Sliding door stuck - relays?
Post by westonwarrior » Sun Jan 09, 2011 12:34 am
Usualy its caused by the closing system not completing its cycle
Its been known for a good thump halfway up the front of the door on the inside to clear it.
or removing the door card and knocking the micro switch in the door which should reset the system
Post by g8dhe » Sun Jan 09, 2011 12:58 am
The relays are in the box at the back of the fixed contacts;
Never heard of the relays giving a problem, its always the microswitch inside the door that is the cause of grief .... so far ;-)
Middle of the door 1/3 up from the bottom and it needs a a REALLY SOLID THUMP or two or more, allegedly :lol: Not had the problem myself ... yet :?
Post by bigdaddycain » Sun Jan 09, 2011 2:40 am
That'd be thumping it from the INSIDE i take it Geoff? :shock:
Post by g8dhe » Sun Jan 09, 2011 12:01 pm
Yes good point!
dobby
Post by dobby » Sun Jan 09, 2011 12:06 pm
Yes, and it has to be a THWUMP about a third up with the flat of the hand about three attempts and enough to hurt your hand :shock:
