Under sealing/Wax oil
the smoker
Post by the smoker » Wed Aug 11, 2010 5:24 pm
hi there. just had a service today done by Adrian in Bury . you can find his number on the Manchester Campers site.
I highly recommend him, ive never met such an Honest Guy as him in the Motor trade.
Anyway the he recommends that before winter that i get her undersealed or wax oiled as the underside of mine is very good and should be done to protect her. I live in the Northwich area of cheshire and would like to get her done, can any of you fine Bongoers put me on to anyone ? or is it a job i could do myself.
thanks
Gary
wormey
Re: Under sealing/Wax oil
Post by wormey » Wed Aug 11, 2010 5:28 pm
You can do it yourself but it is very messy, I had mine done near st albans by rust master who have a few depots across the country.
To have it done by them cost about £400.
Daz and debs
Driver
Post by Driver » Thu Aug 12, 2010 8:25 pm
Hi I am not far from you in Winsford and I can definitely recommend Wheelquick at Wigan give them a call. They did mine prior to me picking it up from them when I bought it. :D
Mazda Bongo Aero 2 ltr Petrol White 2001
rclapp
Post by rclapp » Fri Aug 13, 2010 6:08 pm
You could give ChassisClean :D a shout as they are not far from you in Altrincham.
http://115.124.111.172/chassisclean/?q=node/39
They did mine last year and did a fantastic job. The bloke even gave me a lift back to Stretford (6 miles) after I dropped the Bongo off.
tallbongo
Post by tallbongo » Sun Aug 15, 2010 10:51 pm
I'm a new Bongo owner and the previous owner claimed the underside had been waxoyled. I'm not convinced it has, as although it looks quite solid, there is surface rust on most of it.
What is the best treatment to prevent further degredation of the underside?
Many thanks,
Dave, Elaine & The Ginnébago
95 N Reg 4WD Manual AFT Bongo
Image Image
Post by Doone » Mon Aug 16, 2010 11:38 am
the smoker wrote: or is it a job i could do myself.
This has been asked before and you'll find some advice, ON THIS LINK
If it's been waxoyled it should have waxoyl on it, you'll see (and you can feel) a generally clear or black coating on the metal.
where's Wally???
Post by where's Wally??? » Mon Aug 16, 2010 1:32 pm
I'll second the shout about the guys at Wheelquick excellent service.
Carl
seventiesboy
Post by seventiesboy » Mon Aug 16, 2010 2:25 pm
Without a doubt, go to Wheelquick
tallbongo
Post by tallbongo » Mon Aug 16, 2010 9:44 pm
If it has been done it's worn off now. I'd think it's worth doing again, as for corrosion to happen surely the metal has to come into contact with oxygen (including H2O) so any rust present should not detoriorate further. Obviously a good rub down of the underside would help the sealing process.
However, I've seen comments that contradict this - have I got it wrong? I don't want the underside of my Bongo to look like a VW in a few years if I can prevent it.
Image Image
You've Been Bongod
Post by You've Been Bongod » Mon Aug 16, 2010 10:06 pm
ian taylor in stoke on trent £75 - £80 will last 1 year before needs doing again
