stop the beeping
jutwit
stop the beeping
Post by jutwit » Mon Jul 12, 2010 11:01 am
the beeping when im in reverse and when ileave the keys in and open the door, is so loud its driving me insane, does any body know where these noise makers are located? i just want to make them a bit quieter not remove them, if thats possible?
Alacrity
Re: stop the beeping
Post by Alacrity » Mon Jul 12, 2010 11:07 am
I believe the beeper is behind the panel to the right of your right foot. Just disconnect it I believe (others here will know for sure). I did it on my last Bongo & came out to a flat battery about a week later after I left the lights on all night!! :oops: Still connected on the current Bongo . . .
Post by g8dhe » Mon Jul 12, 2010 11:53 am
You can stop the bleeping for the Key and Doors easy enough by just pulling the plug below apart, as shown, its then very easy to push back together in the future if needed - but it won't make the beep any quieter for the AFT, Reversing or lights left on!;
mikexgough
Post by mikexgough » Mon Jul 12, 2010 11:59 am
the main "beeper" is in the drivers footwell..... Blue coloured box..... I have kept mine but disconnected the Key beep...
Alacrity
Post by Alacrity » Mon Jul 12, 2010 1:23 pm
Ahh that's good to know. Thanks Gentlemen.
jutwit
Post by jutwit » Mon Jul 12, 2010 2:08 pm
i dont want it to stop i just want it to be quieter, i was thinking of putting some tape on what makes the noise. see if that will do it.
mikexgough
Post by mikexgough » Mon Jul 12, 2010 9:27 pm
blue tac also dampens the beeps.... :wink:
Scott
Post by Scott » Tue Jul 13, 2010 1:53 pm
jutwit wrote:i dont want it to stop i just want it to be quieter, i was thinking of putting some tape on what makes the noise. see if that will do it.
You need some of these...
also good for dulling the tones of annoying passengers :lol:
The user formerly known as csmcqueen ;)
スコット
roosmith
Post by roosmith » Thu Oct 04, 2012 6:26 pm
g8dhe wrote:You can stop the bleeping for the Key and Doors easy enough by just pulling the plug below apart, as shown, its then very easy to push back together in the future if needed - but it won't make the beep any quieter for the AFT, Reversing or lights left on!;
Just thought I'd let you know another satisfied customer following this advice! After I had an alarm fitted that fades the interior light up, even with the doors shut the beeping continues as it sees the light on as a door open (that's what I'm assuming although that could be misguided) (and yes the doors are all closed and switches working!).
Hanksy
Post by Hanksy » Thu Oct 04, 2012 6:37 pm
i just cut the blue wire :mrgreen: :mrgreen: :mrgreen:
or was it the red wire :shock: :shock: :shock:
i cant remember
that goes into the beeper box in the drivers foot well, do a search and a bit of reading im sure there is a thread with a photo in ...I also did the one under the steering wheel
both were easy
if you struggle finding it let me know and ill take a pic for you
roosmith
Post by roosmith » Thu Oct 04, 2012 6:42 pm
Thanks jutwit, I just wanted to stop the door and key beeps, I did look at the big blue one, however thought I'd be in the dog house if I ran the battery down leaving the lights on :lol:
rhino-wayne
Post by rhino-wayne » Fri Oct 05, 2012 8:17 am
I've driven several other vehicles since owning my Bongo........& missed the beeps :lol:
The Beeps are the Bongo singing to you :lol:
She loves & cares for you :roll:
:lol: :lol: 8) :lol: :lol:
Diplomat
Post by Diplomat » Fri Oct 05, 2012 9:19 am
The bleep is so strident that, once it leaves the sounder, it is remarkably difficult to reduce by any form of padding etc.
I decided to strangle it at source by poking a broken match stick into the hole in the sounder. It is hard to believe that so much noise can come out of that hole. Although I reduced it by quite a few dBs, plenty of sound also leaks out through the small gap between the back of the sounder and the circuit board.
mikexgough wrote:blue tac also dampens the beeps.... :wink:
Good idea, Mike. I might try some around the gap.
As automatics and flat batteries are not a good combination it is a good idea to at least keep the 'lights on' warning.
The 'door open/key in' bleep is a pain. It can be killed by partly withdrawing the key but that practice brings with it a very high risk of accidentally fracturing the key at one of its narrower points, especially if you have a lot of other weight on your key ring.
Frank
They flew, I took up naturism
Hanksy
Post by Hanksy » Fri Oct 05, 2012 9:24 am
My lights turn off with the ignition so there is no need for the beeper anyway, I don't know if this is standard (probably not )
but worth checking
mikeWalsall
Post by mikeWalsall » Fri Oct 05, 2012 9:57 am
I have disconnected the white block under the steering column to silence the ignition key in / door open beeps, but all the other lights on / reverse / beeping functions work..
I find it quirky (and not in a good way) that my headlights and brake lights still work even with the ignition off ..
On my Toyota, which is the same system I was caught out a couple of times with a low battery even though on checking, no lights had been left on ..
One day after being parked up for a few hours, I was walking back to the car and from some distance away bemused to see the brake lights permanently on ..
Turns out that my old Staffy bull terrier likes to sleep in the drivers foot well ... across the brake pedal ..!!
