Changing Roof tent
DrummieDave
Changing Roof tent
Post by DrummieDave » Mon Jun 14, 2010 7:23 pm
Hi there,
We're about to change our roof tent as the one on the van we bought has no fly sheet! Someone had cut it out...
So I bought a pretty decent second hand one.
I was just wondering if there was a fact sheet/work through sheet or a post showing how to change it over. I'm a member here so can login etc but can't seem to find a specific post.
We have assumed (maybe wrongly) it's not that harder job and it's simply a matter of removing the frame from around the van lid and then slotting in the new tent, then doing the same below.
We'll see! Won't be doing it till the van comes back from having a broken manifold stud removed and new gasket etc so a bit of reading would be good to fill the hours waiting for it's return!
Dave.
Wicker Man
Re: Changing Roof tent
Post by Wicker Man » Mon Jun 14, 2010 7:29 pm
Hi - There's a bit here from Allans Vehicle Services that may be useful to you:
http://www.allansvehicleservices.co.uk/32132.html
Scroll down to the section "Sleeping compartment fabric repair, removal:"
bongomadness
Post by bongomadness » Mon Jun 14, 2010 7:41 pm
You beat me to it wickerman. His is the only site that gives you how to do that in easy picture and plain english sense. Top man !
DrummieDave
Post by DrummieDave » Mon Jun 14, 2010 8:44 pm
Thanks a lot. That's perfect!
321Away
Post by 321Away » Tue Jun 15, 2010 12:39 pm
Make sure you use a P3 screwdriver for the upper screws, thats the BIG philips type as a P2 will round out the screws. put roof 3/4 up, then using a P2 undo the bottom plastic pop out screws, when bottom is loose use P3 to go round the top, the front corners are quite tricky so use a 3/8 ratchet with driver attatchment if you have 1, i start at the back and work to the front, dont worry if some of the inserts come with the screws/roof you can just undo them after and glue back in, i normally leave the middle front for last, after all screws are undone, drop the tent down and release the 2 springs at the back and it should come away nice n easy and as they say in the Haynes bibles, refitting is the reverse of removal lol
Julian
Scott
Post by Scott » Tue Jun 15, 2010 1:52 pm
Also I believe there are two different types of roof tent, on the later models, the AFT goes up a little higher so I would assume the tent is bigger but hopefully someone can confirm this :roll:
The user formerly known as csmcqueen ;)
スコット
Post by mikeonb4c » Tue Jun 15, 2010 2:01 pm
321Away wrote:Make sure you use a P3 screwdriver for the upper screws, thats the BIG philips type as a P2 will round out the screws. put roof 3/4 up, then using a P2 undo the bottom plastic pop out screws, when bottom is loose use P3 to go round the top, the front corners are quite tricky so use a 3/8 ratchet with driver attatchment if you have 1, i start at the back and work to the front, dont worry if some of the inserts come with the screws/roof you can just undo them after and glue back in, i normally leave the middle front for last, after all screws are undone, drop the tent down and release the 2 springs at the back and it should come away nice n easy and as they say in the Haynes bibles, refitting is the reverse of removal lol
Julian
What excellent advice. Another factsheet needed. Most (all) advice on the forum (not checked factsheets as don't have pswd to hand but...) has warned how difficult it is, but none (as far as I can recall) has actually given much hope that those screws can actually be undone by mortal man or woman. Thank you, from all of us =D> =D> =D>
DrummieDave
Post by DrummieDave » Wed Jun 16, 2010 10:48 pm
Thanks a lot. Great advice. The Mrs spent the other night cleaning the tent up and it's come up a treat.
We're getting the van back tomorrow and will let you know how we get on. Need to buy a POP Rivet gun to put those rivets back in . . .
Post by Doone » Thu Jun 17, 2010 4:58 am
Drummiedave, there's more advice on the forum from Rhod, about the pop rivets ON THIS LINK.
DrummieDave
Post by DrummieDave » Thu Jun 24, 2010 11:36 am
Hi there, spent sunday afternoon changing it all over and it went very well. We used the guide from the link here which was very helpful.
I took some piccies and have posted them on facebook but I'm not sure they can be viewed unless I'm connected with someone.
Here is the link.
http://www.facebook.com/profile.php?id= ... 182&ref=mf
Cheers everyone!
Dave.
Scott
Post by Scott » Thu Jun 24, 2010 11:54 am
DrummieDave wrote:Hi there, spent sunday afternoon changing it all over and it went very well. We used the guide from the link here which was very helpful.
Here is the link.
Cheers everyone!
Dave.
is that the
'Share this album with anyone by sending them this public link:'
link form the bottom of the page
スコット
DrummieDave
Post by DrummieDave » Thu Jun 24, 2010 7:24 pm
Ah, that would be this one!
http://www.facebook.com/album.php?aid=1 ... a09ea01908
Thanks, didn't know you could do that!
Scott
Post by Scott » Thu Jun 24, 2010 8:47 pm
DrummieDave wrote:Ah, that would be this one!
:wink:
スコット
