Flashing hold light and speedo not working.
mark.hingston
Post by mark.hingston » Mon Jun 07, 2010 11:58 am
This is a problem which i have had twice since the weekend, to remedy it i have switched off the engine and restarted.
Is this a common fault? If so what can I do about it?
Cheers.
Mark and Julie
1998 Aquamarine Ford Freda
2.5td 4wd aft
Re: Flashing hold light and speedo not working.
Post by rita » Mon Jun 07, 2010 12:08 pm
Hi mark.hingston,
Do you know if your speedo has been chipped,the chip could be faulty or a bad connection..
Bongoplod
Post by Bongoplod » Mon Jun 07, 2010 12:13 pm
Yep,agree with Rita,i had similar problems,got a new chip fitted,problam sorted.
Brian
Post by missfixit70 » Mon Jun 07, 2010 1:17 pm
see if you get a fault code by following the diagnostic procedure in the factsheets. Are there any other symptoms ie dropping out of lock up?
ronhud
Post by ronhud » Mon Jun 07, 2010 2:07 pm
When I had this problem I followed a thread on here and removed the instrument panel, tightened the screws on the back and it cured the problem. Search the forum there should be a thread with a pic of the suspect screws.
Ron
mark.hingston
Post by mark.hingston » Mon Jun 07, 2010 2:46 pm
Thanks for all your thoughts. So it sounds like nothing too serious and I shouldn't postpone my holiday this coming weekend.
BTW we have just returned from the most amazing trip in Europe with the Bongo. Mont Blanc, Italy Austria Germany back to France then home. France passion is a book that lists all the places in France you can stay for F.O.C. Just display the France passion sticker in your window, The owners of the properties are ever so friendly and most of them are campervan owners themselves. All the Aires in France is another guide to where you can stay for free. So if you're off to France this year invest in these books.
Mark and Julie
2.5td 4wd aft
Post by Doone » Mon Jun 07, 2010 3:18 pm
Are there any other sympotms ie dropping out of lock up?
mark.hingston
Post by mark.hingston » Mon Jun 07, 2010 5:34 pm
No other symptons.
Mark and Julie
2.5td 4wd aft
