Post
by Northern Bongolow » Sat May 15, 2010 9:58 pm
years ago when delivering consentrated caustic in my tanker i quickly learned that caustic attacks and in fact eats alluminium.
imagine my surprise when doing tests on how to chemical flush an old sludged up but not leaking coolant radiator i poured into the removed radiator a caustic water mix, i knew that lots of heat would be produced in the following reaction,but what did i forget?? you guessed it,the mix ate the rad in approx 20 mins.
what lessons have you learn and then forget.
dandemann8
Post
by dandemann8 » Sat May 15, 2010 10:04 pm
Bongo no more........... ;-(
blobber
Post
by blobber » Sat May 15, 2010 10:40 pm
Lesson learnt..............Not to let you near my bl**dy radiator.
Lesson forgotten............. hope I never forget not to let you near my bl**dy radiator !!!
Alan & Dot
Yes sir, I can Bongo !!
David Edwards
Post
by David Edwards » Sat May 15, 2010 10:43 pm
Aw so unintentionally funny,lol, I had to order a new rad today as mine is full of crud and sprung a big leak which I hope is the cause of all the problems I have had. Got a brand new one, aluminium cored 2 year warranty, boxed etc, delivered all for £111.00, will arrive Tuesday for fitting..all I need now is a new bloody left arm to drive the bongo with,lol. Got it from a company called budget rads, nice helpful chap to be fair, got a phone number if anyone needs it.
Post
by Northern Bongolow » Sat May 15, 2010 11:03 pm
at least ive got something to attack,feel im turning into steve widdowson.going to cut it up.
mikexgough
Post
by mikexgough » Sun May 16, 2010 7:08 am
Ron Miel
Post
by Ron Miel » Sun May 16, 2010 8:26 am
Northern Bongolow wrote:>
.......what lessons have you learn and then forget.
Too much of this:
...means too little of this:
Ron Miel on Sun May 16, 2010 10:59 pm, edited 1 time in total.
Post
by mikeonb4c » Sun May 16, 2010 11:33 am
Northern Bongolow wrote:years ago when delivering consentrated caustic in my tanker i quickly learned that caustic attacks and in fact eats alluminium.
Crikey - very easily done, a mistake like that. I wouldn't have made the connection I suspect, even though the chemist in me ought to remember. Makes you wonder what exactly the recommended stuff uses to do the job
Post
by francophile1947 » Sun May 16, 2010 12:24 pm
Oops! When I saw your intentions I thought it was a bit drastic, but had no idea it would dissolve the alloy
- bad luck/memory
dobby
Post
by dobby » Sun May 16, 2010 12:52 pm
Looks like Mike's plan of cutting up was the best idea!
BTW how badly sludged was it?
Post
by Northern Bongolow » Sun May 16, 2010 8:03 pm
it would have given someone lots of grief very shortly imo,probably through the summer months,if you get my drift.
catch you at the bash .
dobby
Post
by dobby » Sun May 16, 2010 9:48 pm
Northern Bongolow wrote:it would have given someone lots of grief very shortly imo,probably through the summer months,if you get my drift.
It got replaced when the head went on ours as a precaution as the head failure was due to a mega hose leak.
Either the overheat must have or caused it to sludge up or the sludge help contribute to the head failure i.e. ran too hot for a while?
Mountain
Post
by Mountain » Thu May 20, 2010 4:37 pm
And it produces lots of highly explosive hydrogen gas
http://www.youtube.com/watch?v=t2zSWhf4VUg
Chemistry + Iron Maiden
widdowson2008
Post
by widdowson2008 » Thu May 20, 2010 5:41 pm
Northern Bongolow wrote:at least ive got something to attack,feel im turning into steve widdowson.going to cut it up.
OY!!!!!!!!
Steve
widdowson2008
Post
by widdowson2008 » Thu May 20, 2010 6:02 pm
Double OY!!!!!!!! You lot are making me out to be a butcher
............I'm not.........Honest........well, perhaps a tad
Steve
