Unladen weight?
dollyanna
Unladen weight?
Post by dollyanna » Mon Mar 22, 2010 9:54 pm
Took the Freda in for its MOT today, came back and hour later to be told they couldn't do it cos they didn't know its unladen weight. Not quite sure how all its previous MOTs have been done, but does anyone know the unladen weight of a bongo/freda, or where I can find that info? No idea where the nearest weighbridge is so i thought I would ask on here first!
Test rebooked for Wednesday [-o<
MountainGoat
Re: Unladen weight?
Post by MountainGoat » Tue Mar 23, 2010 12:50 am
SPECIFICATION (SPECS)
EXTERIOR
Exterior dimensions (LxWxH), mm 4585 x 1690 x 2090
Interior dimensions (LxWxH), mm 2830 x 1570 x 1295
Wheel base, mm 2920
Treads (F/R), mm 1465 / 1440
Ground clearance, mm 175
Curb vehicle weight, kg 1860
Gross vehicle weight, kg
Seating capacity, persons 8
Doors number 4
Min.turning radius, m 5.5
Fuel tank capacity, l 65
Hope that this helps you Dollyanna. Someone should be along soon to confirm these figures.
Tony
Colin H F
Re: Unladen weight?
Post by Colin H F » Tue Mar 23, 2010 12:56 am
hi click this link and select bongo spec top right of home page
http://www.allansvehicleservices.co.uk/32132.html
dollyanna
Re: Unladen weight?
Post by dollyanna » Tue Mar 23, 2010 1:37 am
Thank you!! If I just print this off and take it to the garage is that enough do you think?
Colin H F
Re: Unladen weight?
Post by Colin H F » Tue Mar 23, 2010 1:43 am
Yep its been done before
Re: Unladen weight?
Post by rita » Tue Mar 23, 2010 12:23 pm
I think the weight should be on the V5C Registration Certificate.(Vehicle Details)
If your vehicle has not been converted this should show as Mass in service.
Hope this helps.
MountainGoat
Re: Unladen weight?
Post by MountainGoat » Wed Mar 24, 2010 12:47 am
For the record Dollyanna my V5C certificate which gives my Bongo as a campervan with a conversion similar to yours records its weight as 2340 KG Gross.
Good luck for tomorrow.
Tony
Re: Unladen weight?
Post by Bob » Wed Mar 24, 2010 1:23 am
Hopefuly the info provided will do it. If not weighbridge here:
http://www.awjenkinson.co.uk/awj-lockerbie.php
Worth smiling nicely. :)
dollyanna
Re: Unladen weight?
Post by dollyanna » Wed Mar 24, 2010 12:06 pm
I don't appear to have a V5C certificate - should I?
dollyanna
Re: Unladen weight?
Post by dollyanna » Wed Mar 24, 2010 12:08 pm
Oh, hang, on just googled what it is, am I right in thinking that is the registration certificate I got when I bought it? Its just not with the other paperwork yet, I'll have to go and have a dig around.
Re: Unladen weight?
Post by rita » Wed Mar 24, 2010 12:11 pm
dollyanna wrote:I don't appear to have a V5C certificate - should I?
Hi,if you are the registered owner of the vehicle you should have a V5C Registration Document.
Previously known as a Log Book.
dollyanna
Re: Unladen weight?
Post by dollyanna » Wed Mar 24, 2010 12:54 pm
It's ok, I do have one somewhere that I can't quite place immediately, but I have just found the slip you get when you are waiting for the proper thing to come through and that has the weight on it. I'll take that along :)
