Does the rear washer have a separate tank? If so where?
Otherwise, what? a Blocked pipe? Where does that run?
Help. My back window is filthy.
feeling stupid
ashleywengraf
- maxheadroom
Re: feeling stupid
only one bottle but the back will stop working before the front as the pick up is higher in the bottle
Re: feeling stupid
Same tank as front
Question is, does it have a separate pump for the back?
Re: feeling stupid
Yesdobby wrote:Same tank as front![]()
Re: feeling stupid
The bottle and pumps are shown here http://www.lushprojects.com/bongopartsm ... mgno=.html
Parts 76-672 two of them plus the piping round the van.
Re: feeling stupid
Check the level in the bottle under the bonnet, check the pump is pumping & then see if it's become disconnected at the interface between tailgate & body.
Re: feeling stupid
You may just need to wait a little longer for the water to bleed through to the rear jet & push the air out if it hasn't been used in a while??
Re: feeling stupid
hi if you open the rear door and gentley pull the pipework that is in the door you will find a one way valve blue in colour if memory serves,note the little arrow marked on it,remove it and blow throughit till clear,WARNING DONT SUCK.refit carefully and test.
ady.
ady.
