feeling stupid
ashleywengraf
feeling stupid
Post by ashleywengraf » Mon Mar 15, 2010 8:34 pm
Does the rear washer have a separate tank? If so where?
Otherwise, what? a Blocked pipe? Where does that run?
Help. My back window is filthy.
maxheadroom
Re: feeling stupid
Post by maxheadroom » Mon Mar 15, 2010 8:35 pm
only one bottle but the back will stop working before the front as the pick up is higher in the bottle :D
Keep the Faith
dobby
Re: feeling stupid
Post by dobby » Mon Mar 15, 2010 8:36 pm
Same tank as front :D
Question is, does it have a separate pump for the back?
Re: feeling stupid
Post by francophile1947 » Mon Mar 15, 2010 8:39 pm
dobby wrote:Same tank as front :D
Yes :D
Re: feeling stupid
Post by g8dhe » Mon Mar 15, 2010 9:53 pm
The bottle and pumps are shown here http://www.lushprojects.com/bongopartsm ... mgno=.html
Parts 76-672 two of them plus the piping round the van.
Re: feeling stupid
Post by missfixit70 » Mon Mar 15, 2010 9:56 pm
Check the level in the bottle under the bonnet, check the pump is pumping & then see if it's become disconnected at the interface between tailgate & body.
jaylee
Re: feeling stupid
Post by jaylee » Mon Mar 15, 2010 9:57 pm
You may just need to wait a little longer for the water to bleed through to the rear jet & push the air out if it hasn't been used in a while??
Re: feeling stupid
Post by Northern Bongolow » Tue Mar 16, 2010 6:09 am
hi if you open the rear door and gentley pull the pipework that is in the door you will find a one way valve blue in colour if memory serves,note the little arrow marked on it,remove it and blow throughit till clear,WARNING DONT SUCK.refit carefully and test.
ady.
