HELP!From 4 wheel to 2 wheel drive
bongoella
Post by bongoella » Tue Mar 09, 2010 9:03 pm
I have made my Bongo a two wheel drive by undoing 8 bolts and removing the shorter rear prop shaft. This has stopped the back wheels having power .When i read the techie info on this job it sounded much more complicated.I am therefore worried that i have done something very wrong!Can anybody advise!?Thanks.Lorraine
mister munkey
Re: HELP!From 4 wheel to 2 wheel drive
Post by mister munkey » Tue Mar 09, 2010 9:13 pm
Wheres Harry when you need him!!?
Its been done before, worry not . . . . Reassurance will be along shortly.
8)
EDIT:
Just re-read that, Harry took the front drive shaft of I think . . . .
Ignore me, I'll be off getting me coat.
Last edited by mister munkey on Tue Mar 09, 2010 11:19 pm, edited 1 time in total.
dandywarhol
Post by dandywarhol » Tue Mar 09, 2010 11:14 pm
Why did you do it Lorraine?
IMO you're going to very quickly fubar the Viscous Coupling which you're taking all the drive through.
Post by missfixit70 » Tue Mar 09, 2010 11:14 pm
bongoella wrote:I have made my Bongo a two wheel drive by undoing 8 bolts and removing the shorter rear prop shaft. This has stopped the back wheels having power .When i read the techie info on this job it sounded much more complicated.I am therefore worried that i have done something very wrong!Can anybody advise!?Thanks.Lorraine
Because the factsheet is explaining how to disconnect the front wheel drive, making it a rear wheel drive vehicle, yours is now a front wheel drive vehicle.
Post by Doone » Tue Mar 09, 2010 11:19 pm
I agree!
This is how they sometimes tow in a 4WD on a 'spec lift' recovery vehicle and they don't drive well with that prop disconnected.
I'd put it back together.
Post by Bob » Wed Mar 10, 2010 12:00 am
My understanding is drive is normally to the rear wheels, with some oomph being diverted to the front wheels when it senses the back ones slipping.
I think you may well be in for trouble very soon with this set up. :(
Alacrity
Post by Alacrity » Wed Mar 10, 2010 9:30 am
Exactly right in my opinion. The 4x4 unit viscous coupling will overheat very quickly leaving you with no drive & an expensive repair bill. :twisted: #-o Don't use the vehicle like this. If you want to convert it to 2 wheel drive (why??) then remove the front propshaft as stated earlier. 4x4 Bongo's are a rear wheel drive vehicle with the front wheels only driving when needed (via the viscous coupling) - very very simply put. Other vehicles (Honda CRV, Rav4 etc.) are the other way round.
321Away
Post by 321Away » Wed Mar 10, 2010 10:11 am
agree with alacrity, any time i've ever seen it done its always been the front drive thats been disconnected, or it can lead to problems, removing the front drive prop is only marginally more difficult than the back
Julian
