waterpump leak solution?
FREDA MIND
Post by FREDA MIND » Wed Feb 03, 2010 8:18 pm
hi guys, freda has developed a slight leak from the water pump.(a few drips every night).
ive just been searching for a replacement when i came accross this product.
has anyone used anything simular, or can advise or vouch for it????
cheers guys :)
ricky
http://cgi.ebay.co.uk/Head-Gasket-repai ... 4836cd0645
have yourself a midlife chrisis,,,,go buy a bongo!
Rhod
Re: waterpump leak solution?
Post by Rhod » Wed Feb 03, 2010 9:58 pm
Personally, I think I'd go for a replacement waterpump, rather than risk clogging up the cooling arteries of the Bongo - unless you really do need a quick fix.
Post by missfixit70 » Wed Feb 03, 2010 10:10 pm
Got to agree, it's not a hugely difficult or expensive job, if it's leaking, then it's possibly getting a bit old & worn anyway, if that stops, you got no circulation & bang, there goes £1200 on a new head (worst case scenario)
bobngo
Post by bobngo » Wed Feb 03, 2010 10:23 pm
never known one of these quick fixes to work permanently, and usually messes up something else .
nothing like the full and proper fix , also saves on the worry of will it, wo,nt it fix it.!!!!!
tricky
Post by tricky » Thu Feb 04, 2010 12:28 am
FREDA MIND wrote:hi guys, freda has developed a slight leak from the water pump.(a few drips every night).
Take care.. My MG RV8 didn't appear to have a leak at all..no telltale drips, nothing...but it was overheating if stuck in traffic.
Turned out that the water pump was leaking but only when running and was throwing the water out. Finally diagnosed when the bearings started to make a sound and the mechanic and I worked out by the frequency of the noise what it must be. Only after partial strip down could the evidence of the water be seen as it was flashing off on the hot parts as soon as it escaped.
So, the few drips might actually be a lot more when running,
FREDA MIND
Post by FREDA MIND » Thu Feb 04, 2010 9:05 am
cheers guys, i must agree, gonna get this done asap.
thanks for your advise, sometimes two three or lots of heads are better than one :lol: :lol:
what a wonderful forum this is!! :D
thanks as always
ricky 8)
Post by Doone » Thu Feb 04, 2010 3:16 pm
I expect you're already doing this, but check the coolant level and keep it topped up while you're waiting to fix the leaking water pump. :)
