I have a 96 2.5td auto. I have discovered that my gear box oil is low but can't seam to find where to top it up. If someone can advise me that would be great?
Dan
Top up gear box oil
Re: Top up gear box oil
Through the dipstick hole - use Dexron 3 spec ATF. Level should be checked with the oil hot and gearbox in D (with handbrake on and wheels chocked
Ok thanks. I thought that might be the case but I was looking for a bigger intake
That would be too easyDanop wrote:Ok thanks. I thought that might be the case but I was looking for a bigger intake
& engine runningfrancophile1947 wrote:Through the dipstick hole - use Dexron 3 spec ATF. Level should be checked with the oil hot and gearbox in D (with handbrake on and wheels chocked)
