Top up gear box oil
Danop
Top up gear box oil
Post by Danop » Sun Jan 31, 2010 1:29 pm
I have a 96 2.5td auto. I have discovered that my gear box oil is low but can't seam to find where to top it up. If someone can advise me that would be great?
Dan
Re: Top up gear box oil
Post by francophile1947 » Sun Jan 31, 2010 1:31 pm
Through the dipstick hole - use Dexron 3 spec ATF. Level should be checked with the oil hot and gearbox in D (with handbrake on and wheels chocked 8) )
Danop
Post by Danop » Sun Jan 31, 2010 1:50 pm
Ok thanks. I thought that might be the case but I was looking for a bigger intake :)
Post by francophile1947 » Sun Jan 31, 2010 1:52 pm
Danop wrote:Ok thanks. I thought that might be the case but I was looking for a bigger intake :)
That would be too easy :lol: :lol:
Post by missfixit70 » Sun Jan 31, 2010 2:11 pm
francophile1947 wrote:Through the dipstick hole - use Dexron 3 spec ATF. Level should be checked with the oil hot and gearbox in D (with handbrake on and wheels chocked 8) )
& engine running
