Twenty litre jerry can
HarryBongo
Post by HarryBongo » Wed Dec 30, 2009 5:21 pm
...quick question.
Are these ok in most garages? I have a couple of diesels so it would be handy, but I ain't buying one if it causes hassle at the forecourt.
:roll:
scanner
Re: Twenty litre jerry can
Post by scanner » Wed Dec 30, 2009 5:57 pm
Diesel is not subject to the Petroleum Act it only applies to "Petroleum Spirit" - Petrol to you and me. The signs on the forecourt should actually only refer to "petrol" or "petroleum spirit" anything else and they are illegal.
So there are no restrictions on buying diesel (well you can't just put it in a carrier bag of course) but any secure sealed container of almost any size is OK and quite legal.
If anybody tries to tell you otherwise tell them to "go off and read the Act" or words to that effect.
Diesel is so much safer than that awful smelly, toxic, explosive stuff.
PS I used to run a filling station and my son still does.
HarryBongo
Post by HarryBongo » Wed Dec 30, 2009 6:08 pm
Thank you Mr Scanner.
New Year's Eve purchase sorted. :)
scanner
Post by scanner » Wed Dec 30, 2009 6:37 pm
HarryBongo wrote:Thank you Mr Scanner.
Just don't use any you bought at the height of summer in the depths of winter, as it is different stuff then and could "gel" under extreme conditions.
Post by mikeonb4c » Wed Dec 30, 2009 6:45 pm
What a wealth of experienced practical talent we have on here =D>
stilldesperate
Post by stilldesperate » Wed Dec 30, 2009 7:02 pm
Could you expand on that, please Scanner.
SD
"The older I get, the faster I was"
Post by francophile1947 » Wed Dec 30, 2009 7:06 pm
Winter diesel has different additives to stop it waxing - see http://www.bp.com/liveassets/bp_interne ... ummary.pdf
scanner
Post by scanner » Wed Dec 30, 2009 7:19 pm
In short it contains anti-gelling additives which saves having to add a small amount of petrol/paraffin or light a fire under the fuel tank (yes lorry drivers used to do just that!) read here http://trucknetuk.com/phpBB/viewtopic.php?f=2&t=53736.
And see here...
http://www.youtube.com/watch?v=sUxmflYi ... re=related
brorabongo
Post by brorabongo » Thu Dec 31, 2009 1:17 am
I believe in some places (parts of Canada anyway) they leave the truck engine running constantly, (like overnight) to stop it from freezing up.
ボンゴの激怒 pictures
Post by bigdaddycain » Thu Dec 31, 2009 1:46 am
If you've ever watched the programme " Ice road truckers" you'll have noticed that the engines in trucks during sub-zero temps once started cannot be switched off again (apart from servicing in a heated workshop) So a healthy engine is likely to run for months without being switched off. :shock:
Post by bigdaddycain » Thu Dec 31, 2009 1:56 am
You are correct of course.... (strictly speaking) But the reality is that the forecourt attendant doesn't HAVE to sell you anything... If that particular person isn't happy with what you are dispensing the diesel into, then they'll shut off the pump, simple as that. I've had this done on me on 3 occasions, (after they spotted me adding veg oil into the tank AWAY from the pump) Then simply not switched on the pump to dispense the fuel, saying I'd added an unknown additive to MY fuel on THEIR forecourt! #-o
I used to mix my veg oil & diesel in two 20 litre Jerry cans in the boot of my estate car, i had to "sneak" the diesel into the cans, i used to pretend to be filling up my car on the "blind side", when in fact i was filling the jerry cans in the boot. :lol: Other people filling up their cars would actually "grass" on me (especially taxi drivers), then it was pump switched off time! :roll:
I took in a print out of the customs and excise sheet, i may as well have produced some second hand toilet paper for all it was worth... Bottom line? If they aren't happy with what you are dispensing whatever fuel into, they'll simply switch off the pump.
scanner
Post by scanner » Thu Dec 31, 2009 2:10 am
bigdaddycain wrote: You are correct of course.... (strictly speaking) But the reality is that the forecourt attendant doesn't HAVE to sell you anything... If that particular person isn't happy with what you are dispensing the diesel into, then they'll shut off the pump, simple as that. I've had this done on me on 3 occasions, (after they spotted me adding veg oil into the tank AWAY from the pump) Then simply not switched on the pump to dispense the fuel, saying I'd added an unknown additive to MY fuel on THEIR forecourt! #-o
You're quite correct but that is simply their ignorance/contrariness and my response is to go elsewhere. If I'm ever questioned I just say it's for a JCB or mini-digger on site and ask THEM what the problem is as I'm not buying petrol, just diesel and such a container is legal for that. But I haven't had that happen for years. I find it best to use real filling stations though, not amateurs like Tesco/Asda etc., who use people who don't really know the rules as they were probably on an ordinary check-out the day before.
Shell is better (IMHO) and down here noticeably cheaper than RipoffCo.
Post by bigdaddycain » Thu Dec 31, 2009 2:25 am
How did you guess? Yes that usually happened at a supermarket petrol station!
2sticks
Post by 2sticks » Thu Dec 31, 2009 10:34 am
HarryBongo wrote:...quick question.
:roll:
"Screwfix" sell a 10 litre version in red identical in function and shape to the old army ones.
I have 4 and they are much more convenient and lighter than the 20 litre ones and I never
have any bother filling them up, even with petrol - for the garden machinery.
scanner
Post by scanner » Thu Dec 31, 2009 11:24 am
bigdaddycain wrote:How did you guess? Yes that usually happened at a supermarket petrol station!
Exactly :roll:
They are told they mustn't let people have "petrol" in any thing other than the green plastic cans and they are the sort of people who don't know the difference between petrol and diesel.
Ever noticed that it is only the supermarkets (esp. Tesco) that have signs to "Petrol" and "Petrol station" instead of to "Fuel" and "Filling station".
Amateurs............. :roll:
