automatic gearbox oil
Sandy
Post by Sandy » Mon Dec 21, 2009 3:48 pm
Can anyone tell me the types and amounts of oil required for the automatic gearbox, transfer box and rear differential on a 1999 4WD Bongo? Just had a repaired gearbox fitted but not sure about the oil.
Sandy
Re: automatic gearbox oil
Post by Ian » Mon Dec 21, 2009 4:06 pm
Sandy, have emailed you. :D
Transfer Case = 1.6 litres of GL5
ATF = 5 litres of Dextron 3
Rear Diff = 1.4 litres of GL5 (or GL6 if you have Limited Slip Differential)
Post by missfixit70 » Mon Dec 21, 2009 5:43 pm
If the gearbox has been reconditioned/repaired, you may need more than 5 litres, it depends how much work has been done & how much oil was draind from the torque converter, cooler & pipework & all the rest of the gubbins. The most I've had to replace on one so far is about 7 litres.
Keep us posted on how much you have to use, make sure you check the level with engine warmed up properly, running, both brakes on range slowly through the gears , let it settle in D, & take the reading with it running. Check it again after 50 miles or so after filling up.
