airbag problem
naomibarrett
airbag problem
Post by naomibarrett » Wed Nov 18, 2009 9:11 pm
can anyone help me. I have a flashing red airbag warning light coming on from time to time. I have read the manual and its says i need to go to my dealer. Is there any way this problem can be solved by myself.
naomi and steve barrett.
mister munkey
Re: airbag problem
Post by mister munkey » Wed Nov 18, 2009 9:20 pm
Airbags only have a limited lifespan. chances are it or some ancillaries associated with it have got past their Best before date.
How to disable the warning lamp was covered recently here
http://www.igmaynard.co.uk/bongo/forum/ ... ht&start=0
Re: airbag problem
Post by g8dhe » Wed Nov 18, 2009 9:26 pm
I don't there is much you can check, other than that the connectors to the Bags and to the control box are fully plugged in - have you had any work done on the vehicle recently ?
The control box is mounted under the dashboard roughly in-line but to the right a little of the gear stick, it controls the dashboard light directly, it has only one connector on it, and the wiring loom is pretty much direct to the bags with connectors at the bags themselves, the steering wheel also has an additional connector on the column to allow its removal.
naomibarrett
Re: airbag problem
Post by naomibarrett » Wed Nov 18, 2009 9:36 pm
g8dhe wrote:I don't there is much you can check, other than that the connectors to the Bags and to the control box are fully plugged in - have you had any work done on the vehicle recently ?
thanks very much for the tip i will give it a try.
naomibarrett
Re: airbag problem
Post by naomibarrett » Wed Nov 18, 2009 9:40 pm
mister munkey wrote:Airbags only have a limited lifespan. chances are it or some ancillaries associated with it have got past their Best before date.
thanks for the info ,i looked on the link and it says try disconnecting the battery which should reset the computer. I will give this a go.
stringman
Re: airbag problem
Post by stringman » Fri Nov 20, 2009 10:31 am
Isn't this light a warning light there to warn you that there is a problem with the SRS system. Therefore isn't simply disconnecting the light a bit of a Homer Simpson thing to do as the fault will still be there and could cause the system to fail to deploy if you were in an accident or even to deploy in error?
Tin top Bongo camper, Peugeot Partner Combi, Kawasaki ZRX1100, Yamaha SR250SE
Re: airbag problem
Post by g8dhe » Fri Nov 20, 2009 11:25 am
I would agree with that ! The thread discussed stopping the light flashing when the steering wheel was replaced with a non-SRS wheel i.e. no air bag installed.
dandywarhol
Re: airbag problem
Post by dandywarhol » Fri Nov 20, 2009 6:48 pm
A friend of mine had a flashing airbag light on his Golf - he drove around with a pin between his teeth just in case............................................... :twisted:
westonwarrior
Re: airbag problem
Post by westonwarrior » Fri Nov 20, 2009 8:56 pm
dandywarhol wrote:A friend of mine had a flashing airbag light on his Golf - he drove around with a pin between his teeth just in case............................................... :twisted:
:lol: :lol: :lol: :lol: :lol:
