Oil filters
alexknill
Oil filters
Post by alexknill » Fri Nov 06, 2009 3:14 pm
Does anyone know if Halfords do an oil filter to fit 2.5td?
Also, I've read the document about oils - which is the best to use?
I've just looked and realised that the Bongo needs an oil change (done just over 5000km) - I have a chance to do it this weekend and can't use Bongo Fury shop until 16th!
Re: Oil filters
Post by Muzorewa » Fri Nov 06, 2009 3:36 pm
Sounds like me & thee are the only people who change our oil at 5,000km intervals, which for me means every 4 or 5 weeks :?
Re: Oil filters
Post by francophile1947 » Fri Nov 06, 2009 3:44 pm
They won't list a filter but, if you look at the Compatible Parts database in the Member's Area, they should be able to look it up by comparing other makes part numbers - usually cheaper from other motor accessory shops though :wink:
mikexgough
Re: Oil filters
Post by mikexgough » Fri Nov 06, 2009 4:27 pm
or even local Motor factors........ any of these will do - as they are the same filter.....different maker...........
AC X572
ADL ADC42104
ADL ADC42105
ALCO SP997
AMC M0400
AMC M0400K
AMC MO400
BOSCH 0986452042
BOSCH P2042
CHAMPION K270
CLEAN DO827
COOPERS Z1041
CROSLAND 2087
DELPHI FX0152
FIAAM FT5151
FILTRON OP587
FRAM PH6355
HYUNDAI 2630042000
JAPANPARTS JFO505
JAPANPARTS JFO505P
KIA OK55212603A
KNECHT-MAHLE OC274
MANN & HUMMEL WP928/81
MANN & HUMMEL WP928/83
MAZDA VSY114302
MICRO T7317
MITSUBISHI MD069782
MITSUBISHI MD069785
MITSUBISHI MD184086
MOTAQUIP VFL304
NIPPARTS J1315005
PBR BC1211
POWERTRAIN PMFL145
PURFLUX LS740A
PUROLATOR L27998
PUROLATOR L37733
QH QOF5508
RYKO Z313
SOLID AUTOS M302004
TECNOCAR R1302
TECNOCAR RD1001
TEHO OK161
TJ FB5508
UFI 23.237.00
UNION C321
UNIPART GFE329
VIC C306
alexknill
Re: Oil filters
Post by alexknill » Sun Nov 08, 2009 8:40 pm
Thanks for the advice
SAS in Harrogate were brilliant!
chiefster1976
Re: Oil filters
Post by chiefster1976 » Mon Nov 09, 2009 10:52 am
You have RYCO /RYCKO Z313. is this a correct oil filter for 2.5TD? I have seen ryco Z9 in my local motor factor in Australia, same filter that fits my 2.5TD Mazda B2500 UTE... Not sure if it will fit ??
mikexgough wrote:or even local Motor factors........ any of these will do - as they are the same filter.....different maker...........
AC X572
ADL ADC42104
ADL ADC42105
ALCO SP997
AMC M0400
AMC M0400K
AMC MO400
BOSCH 0986452042
BOSCH P2042
CHAMPION K270
CLEAN DO827
COOPERS Z1041
CROSLAND 2087
DELPHI FX0152
FIAAM FT5151
FILTRON OP587
FRAM PH6355
HYUNDAI 2630042000
JAPANPARTS JFO505
JAPANPARTS JFO505P
KIA OK55212603A
KNECHT-MAHLE OC274
MAZDA VSY114302
MICRO T7317
MITSUBISHI MD069782
MITSUBISHI MD069785
MITSUBISHI MD184086
MOTAQUIP VFL304
NIPPARTS J1315005
PBR BC1211
POWERTRAIN PMFL145
PURFLUX LS740A
PUROLATOR L27998
PUROLATOR L37733
QH QOF5508
RYKO Z313
SOLID AUTOS M302004
TECNOCAR R1302
TECNOCAR RD1001
TEHO OK161
TJ FB5508
UFI 23.237.00
UNION C321
UNIPART GFE329
VIC C306
Racing green with extras!!Self build full side conversion which rocks!!!
