how hot is too hot
stevedon
how hot is too hot
Post by stevedon » Thu Oct 08, 2009 9:54 am
how hot is too hot.whatis the maximum temp a diesel should reach,?where should i set my tm2,also what is the nornal running temp~
miker
Re: how hot is too hot
Post by miker » Thu Oct 08, 2009 10:15 am
I'll try and answer part of your question/s as best I can. I recently fitted the temp alarm gismo to my bongo and the 'true' reading on the temp gauge was about 1mm before the 'H'. Having read other peoples posts that it should read approx' the 1 o'clock position (the thermostat opens at 80 deg c so I suppose this position equates to about the same) mine was obviously reading way too high. Haydon had said in one of his posts to try the thermostat if nothing else is obviously wrong and it's cheaper than assuming a blocked radiator.
So I changed the thermostat, hey presto, engine now running at approx' 1 o'clock position or a full 1CM!! from the 'H' on the gauge during everyday runnning. Quite a difference!
I have my alarm set on 4.5 and so far had no alarms since changing the thermostat! :D
stevedon
Post by stevedon » Thu Oct 08, 2009 10:27 am
thanks , i should say new head new rad new pump new stst,but im not sure where to set the alarm on my tm2 105deg 110 deg?
widdowson2008
Post by widdowson2008 » Thu Oct 08, 2009 10:54 am
stevedon wrote:how hot is too hot.whatis the maximum temp a diesel should reach,?where should i set my tm2,also what is the nornal running temp~
I asked the same question - see the following for replies:
http://www.igmaynard.co.uk/bongo/forum/ ... =1&t=30934
My TM2 is currently set at 115 and the engine sounds fine (the sensor cable is attached at the front end of the block, passenger side-thats left in UK)
The above thread has someone with theirs set at 123
Steve
Post by haydn callow » Thu Oct 08, 2009 3:24 pm
That is no longer the recommended place to locate the sensor for the TM-2...It is close to the exaust and in no way reflects the coolant temp....for some time now we have been suggesting it is fitted to one of the tapped holes on the rear of the head ---to get at this point, pull back the bit of carpet between the seats (at the rear) and remove the large cover.....you can then see the correct holes....once this is done your TM-2 should be around 90 for normal driving and 100 if towing. This is pretty close to the coolant temp
Triple/R
Post by Triple/R » Thu Oct 08, 2009 4:04 pm
haydn callow wrote:That is no longer the recommended place to locate the sensor for the TM-2...It is close to the exaust and in no way reflects the coolant temp....for some time now we have been suggesting it is fitted to one of the tapped holes on the rear of the head ---to get at this point, pull back the bit of carpet between the seats (at the rear) and remove the large cover.....you can then see the correct holes....once this is done your TM-2 should be around 90 for normal driving and 100 if towing. This is pretty close to the coolant temp
Yes just like mine--it hovers around 88/90 normal driving--but towing caravan (last week) reached 95 max mainly Motorway driving--mine is set at 102
hope that helps.
Regards Ray & Christine
