Aero wipers...
jaylee
Aero wipers...
Post by jaylee » Thu Oct 01, 2009 8:18 pm
Are they any good..?
References of best place to source from..
Cheers you lot!! :D
Re: Aero wipers...
Post by Doone » Thu Oct 01, 2009 8:23 pm
Hubby had them on a Toyota but didn't like them as they juddered, but that's the only time he's tried them. Bosch make some but I don't know if they make them for bongos.
dandywarhol
Re: Aero wipers...
Post by dandywarhol » Thu Oct 01, 2009 8:23 pm
Heathrow? Luton?
daveblueozzie
Re: Aero wipers...
Post by daveblueozzie » Thu Oct 01, 2009 8:24 pm
do you mean these, #-o they are brill got them on my bongo.
http://cgi.ebay.co.uk/Mazda-Bongo-RETRO ... 286.c0.m14
Lost without my Bongo.
jaylee
Re: Aero wipers...
Post by jaylee » Thu Oct 01, 2009 8:27 pm
I'm in the meerkat for some new wipey's & was wondering if they might skip on the longer passenger side arm?
Re: Aero wipers...
Post by missfixit70 » Thu Oct 01, 2009 8:31 pm
I've recently fitted them to mine, got 2 from ebay for the front, the large one (drivers side) wasn't properly wiping on the bottom 3 inches or so of the blade at the top of the wipe, had to bend the blade a bit to make it work proper, got one for the rear from Trago Mills when I was there, got a 17" on with no fouling anywhere, but again it's not wiping the bottom few inches of the blade at the top of the wipe, even after bending it in a bit. Going to try & increase the tension on the spring on the arm if I can as it does seem a bit slack.
I still remain to be convinced they are any more effective than normal wipers, they certainly look a bit sleeker though, even with my modified wiper arm monuted squirters, still to be refined :wink:
jaylee
Re: Aero wipers...
Post by jaylee » Thu Oct 01, 2009 8:34 pm
daveblueozzie wrote:do you mean these, #-o they are brill got them on my bongo.
Yours certainly look more symmetrical than the ones i was looking at Dave.. http://cgi.ebay.co.uk/Mazda-Bongo--High ... 2001r15046
Fast dispatch??
mikexgough
Re: Aero wipers...
Post by mikexgough » Thu Oct 01, 2009 8:35 pm
got mine from Tesco, they are usually £6 each but I got mine on offer at £4.....
I just got them to the size that the Bongo standards are...and I have had no problems with them
jaylee
Re: Aero wipers...
Post by jaylee » Thu Oct 01, 2009 8:40 pm
missfixit70 wrote:I've recently fitted them to mine, got 2 from ebay for the front, the large one (drivers side) wasn't properly wiping on the bottom 3 inches or so of the blade at the top of the wipe, had to bend the blade a bit to make it work proper, got one for the rear from Trago Mills when I was there, got a 17" on with no fouling anywhere, but again it's not wiping the bottom few inches of the blade at the top of the wipe, even after bending it in a bit. Going to try & increase the tension on the spring on the arm if I can as it does seem a bit slack.
I got Bosch's all round on mine they're starting to go home.. The rear never wiped the top 2 inches, i put down to the arm tension.. The passenger skips the middle 3..
Had a crazy drive back from a gig to the hotel in Dutch fog, I don't want a repeat! :shock:
Re: Aero wipers...
Post by Doone » Thu Oct 01, 2009 8:45 pm
Had a crazy and agonisingly slow drive back from Lands End once in lashing rain with no wipers, just the passenger hanging out the window, using the broken wiper to wipe the windscreen. He got so very wet. :lol: 8) Why didn't we stop and wait for the rain to stop? :?
scanner
Re: Aero wipers...
Post by scanner » Thu Oct 01, 2009 8:46 pm
mikexgough wrote:got mine from Tesco, they are usually £6 each but I got mine on offer at £4.....
Ditto and much as it pains me to recommend anything from Tesco yes they are well worth the money.
jaylee
Re: Aero wipers...
Post by jaylee » Thu Oct 01, 2009 8:57 pm
Years ago i drove my girlfriends Maestro back from Edinburgh's Hogmanay & the drivers arm came loose on the spigot.. I was stopping & tightening it every few miles with the only tool in the car, a skinny pair of pliers.. #-o
Stop press.. I have just been reliably informed my girlfriends Micra wiper needs replacing now.. :lol:
Tesco it might be!!
Re: Aero wipers...
Post by Simon Jones » Thu Oct 01, 2009 9:08 pm
I got the Tesco ones too & I was not quite so impressed. The fin is on the lower edge such that it tends to force the air between the blade & glass which makes it lift away from the 'screen at higher speeds. If the fin was the other way round then it would force the blade towards the glass. I'm sure better quality / design would be more effective. Just my personal observations. :|
jaylee
Re: Aero wipers...
Post by jaylee » Thu Oct 01, 2009 9:20 pm
Certainly after eyeing up the the blades on Dave's link
Do you think the Tesco ones were designed for the LHD market?
Been looking at the site there's no real clear picture...
scanner
Re: Aero wipers...
Post by scanner » Thu Oct 01, 2009 9:55 pm
Simon Jones wrote: I got the Tesco ones too & I was not quite so impressed. The fin is on the lower edge such that it tends to force the air between the blade & glass which makes it lift away from the 'screen at higher speeds. If the fin was the other way round then it would force the blade towards the glass. I'm sure better quality / design would be more effective. Just my personal observations. :|
If you decipher the instructions (hidden way in the packing) they can be reversed................ :wink:
I used them for over a month before I found the instructions when fitting another one to a different car. :roll:
