new head or engine
stevedon
new head or engine
Post by stevedon » Wed Sep 30, 2009 7:33 am
well ive finally given up,my head im sure is cracked.impossible to bleed due to bubbles.Tthe options new bare head at $1200nz or complete jap import engine for $1795 .what are your thoughts the motor has done 200+ ks.There are no reconditioned heads here in nz.has anyone bought a jap imported engine ?
Chris P
Re: new head or engine
Post by Chris P » Wed Sep 30, 2009 8:40 am
I bought a new head about 20K ago, and have been very pleased with the result.
It went at about 180K km, and my garage said that there was an outside chance it was the engine rather than the head, as it is so complex to test the head, but it seems to have been fine, taken it on several long journeys since.
Is the whole engine new or reconditioned? I was a bit put off reconditioned engines by a few of the stories on the forum, where when it didn't work, the engine suppliers said "it is the way that the person you got to fit the engine did it, our engine was fine".
I decided that if I did go that way, I'd go to the people supplying the engine to have it fitted, so I could say "I don't care why it doesn't work , it's your fault - fix it."
Hope that helps.
Chris
stevedon
Post by stevedon » Thu Oct 01, 2009 5:34 am
just found a head brand new for $600nz @ £340 what is interesting is that its a japanese copy??
helen&tony
Post by helen&tony » Thu Oct 01, 2009 7:37 am
That sounds very interesting...some members have had problems with "pattern" heads, but they weren't Japanese...If you do use one, let us know, and how easy they are to find...It may help one or two in the UK
dandywarhol
Post by dandywarhol » Thu Oct 01, 2009 8:16 pm
There was an interesting discovery by someone on here recently that some pattern heads don't have a reccess in the head where the cam cover bolts sleeves/spigot fit. This would indicate to me how good the copy is......................
Post by Doone » Thu Oct 01, 2009 8:31 pm
That was Tim (Samuel) the info about the recess is HERE
